Adria Sonic - This panel…….
Spain
Adria Sonic 700i SL
Anyone know what’s behind this panel, or even better how to remove it? Got a horrible annoying rattle / knocking from behind this panel
Mine was the control panel with all sorts of wires and stuff behind it!!
Assuming it's similar to our Adria, I think the awning has a fixing behind there plus some wires for the light over the door. Most of the other wiring seems to come up behind the fridge freezer and terminate behind a panel in the cupboard above the fridge. I found a sat dish cable and solar cable behind that panel aswell.
Thanks,
can eliminate awning fixing, as they are further along, but need to find it’s fixings and remove as the noise is bloody annoying 🥴
Assumed you’ve looked inside and the left and right to see if there are fixings.
Yep, it appears there are two screw covers underneath, but to access those the fly screen has to be removed 🥲
I find my Adria is built very well, and due to this the can be disassembled and reassembled, although you may well need to remove a few parts to get to everything.
