Noticed when we used the van last week that one of the rear locker doors had become stiff to open/close. I have taken the door off the hinges and the top hinge operates fine and comes out of the frame part nice and easy with no evidence of damage, wear, or corrosion.
However, the bottom hinge is a different story and is well and truly seized. I can rotate it using an adjustable spanner (with a fair bit of effort) but have only been able to move it a couple of mm in a downward path (to remove). I suspect it is probably bent slightly and/or corroded. I have loaded the tube with plus gas (as suggested on another thread), and will leave overnight to see if it gets any easier. If I can get it out I can clean it up and have a go at straightening it if necessary.
I have been searching other threads and checking t’internet to try and find suppliers for a replacement hinge part but no joy so far.
We’re supposed to be off to France on Tuesday and so I really need to get it sorted pronto.
Any suggestions or advice would be appreciated.
