It's advantage is that it is injected downstream of the engine so cannot have any effect on power output, longevity, engine sensors, etc. In most cases it can replace EGR which is the opposite in terms of power output, engine sensors, etc. The only downsides are the inconvenience of yet another fluid to keep an eye on and life of the associated cat.
I have been using AdBlue for nearly 4 years now and have not had any problems.
The engine is Mercedes 316 CDI 2.2l 163ps. Like many motorhomes it stood idle for weeks in the winter. I don’t think regular use is any more of an issue with AdBlue than with other diesel engines but I am not an expert. I am taking delivery of a new motorhome tomorrow which does not have AdBlue but relies on EGR. If anything I suspect I will need to make sure the EGR system gets properly exercised more than the AdBlue one did.Thank, that is reassuring, what engine do you have and is regular use a factor?
From time to time I would check the AdBlue gauge and when it got a bit below half I would tip in another container of AdBlue. On my A class the filler was a bit awkward but not impossible, not that much different from topping up the screen washers though perhaps I was a bit more careful not to splash it around.
Higher mileages involved - but plenty of problems with adblue in HGV's. A quick google will enlighten you but corrosion in the tanks, and nox sensors seem to be common. Even looking in the neck of the tank of a few year old one and you will see a crusty build up. The issues manifest them by unreliable tank status readings and - more annoyingly limp mode.
IMHO its the EU's unrealistic rush that have forced manufacturers to adopt adblue and I strongly suspect we will look back and wonder why we ever let them do it.
The new one is a Carthago on a Fiat chassis. Possibly one of the last to come off the production line before the new Fiat ones come out with AdBlue.Thank you, what is the make of the new van?
Retired now but got mates still in trade and say that adblue problems are now a regular thing now. Just something else to go wrong.Higher mileages involved - but plenty of problems with adblue in HGV's. A quick google will enlighten you but corrosion in the tanks, and nox sensors seem to be common. Even looking in the neck of the tank of a few year old one and you will see a crusty build up. The issues manifest them by unreliable tank status readings and - more annoyingly limp mode.
You might get a good deal on a 2019 model from a dealers stock. They are rumoured to trying hard to shift old stock before Euro6D becomes mandatory. I believe the derogation that will still allow some older engines to be registered is limited.I want to buy a new van but all seem to be adblue from 2020.
