Jeff James
Hi all,
I have just replaced a leaking water pump on my motorhome with the exact replacement, a Shurflo Trail King 7L 30psi pump (12v). I also purchased a Shurflo accumulator, as I have experienced some water hammer on the tap furthest from the pump. The accumulators used to be sold pre-pressurised to 20 or 30psi, but now they are sold discharged and you need to pump them to the "Correct" pressure. However there is no pressure guide in the installation instructions, but there is a comment that a 45psi pump usually kicks in at about 30psi, so the accumulator should be set to 30psi. I am assuming that the accumulator pressure needs to be about 2/3rds of the pump operating pressure, so for my pump, I should set the accumulator to 20psi? This is also one of the 2 pressures that the accumulators used to be sold pre-pressurised to.
Would appreciate some advice/guidance, if my reasoning is about right, before installing the accumulator?
Jeff
Jeff
