A year of Ecotree lithium
Hymer Exsis
20 years
I have been very lucky in winning more than one battery from Ecotree, I installed them a year ish ago now and detailed how in the thread below.
So after a year it’s probably time to review them and see if it was worth the swap.
The plus side is numerous, they charge very quickly from whatever source I use and having two means plenty of capacity. We always opt for no hook up if possible and even this time of year, we are self sufficient with a bit of driving.
In Summer, there is so much excess we can run the absorption fridge all day on the solar and still have plenty of battery left all night.
This weekend we have been away and used about 20ah first night, the kids trainers were soaked so I was able to run a fan heater off the inverter to dry them this morning.
This is after 48 hours of being off hookup with one small drive of 30 minutes. I reckon we could last 4 days if we were careful with ease.
Here we are now driving back and they are quickly refilling from the B2B after using the fan heater.
After a year of use, there will usually be something you would do differently, I can’t say I would in this case. The B2B is great and the solar controllers seem to work well too.
One minor niggle is I never keep them at 100% when I am not using the Motorhome, I therefore have to ensure they are pulled down to about 80%, but that’s not really difficult.
The original EBL works fine charging them and the shunt tells me they get to 100% charged when on it. I know when they have stopped as you can see the voltage go up and the current throttle back to 0. I wouldn’t change the charger to a lithium one if you have a gel profile.
The batteries are performing faultlessly and seem a quality unit built to last. I can certainly say they have been a good investment for me.
I suppose to sum up, it’s been well worthwhile for me making the swap. I don’t have battery anxiety anymore and no topping up of the cells. Added bonus is I have saved 25kg of payload for double the capacity.
Only downside I can ever see is the initial cost, but given I think they will outlast lead acid by some margin, it may be cheaper in the long run.
Hope it helps some others considering swapping over.
Thank you for that. On my to do list for next year.
Take lots of pictures and update on your progress. I love threads like that. :-)
Thank you for the helpful review. We’ve had two 110ah Ecotree lithiums fitted by Oaktree (along with the associated Victron gear. So far, very pleased but hardly given them a test. Parked up in storage with no solar or hook up and it‘s been over 10 days and still reading 88%. We can‘t monitor the vehicle battery but as we have a battery master, we assume if is drawing sufficient charge to keep it topped up. Will go and check it tomorrow.
I always keep them at 80% if I can so the battery master cuts in sooner due to the higher voltage.
Is that a Victron smart shunt? It looks to give you a really useful readout.
Are they difficult to fit? I have a Victron smart solar controller so already have the app. They seem to make brilliant kit. Is the smart shunt pricy?
Agree, wholeheartedly about LiFePO4. We only have a single 110Ah one but we haven’t had to use EHU once since installing it (with B2B, etc.). Together with the eddievanbitz batterymaster, it’s been one of the best upgrades.
Even better, I now use the MH’s former lead-acid leisure battery together with a Victron 50W solar panel to run the chickens’ electric fence. Win win!
Smartshunt is about £125. No monitor with it so you use the app.
Installation is simple enough if you have a crimping tool to make up the necessary ends for your cables. The Smartshunt, perhaps oddly, uses 10mm dia bolt holes, rather than the more standard 8mm on most battery terminals.
I can’t add more than Kannon Fodda has, it’s an easy install as long as you have the 10mm terminals.
It’s really useful to check everything is working too, no guessing about voltages etc.
I’ve only just seen this post of over two years ago and should be grateful if someone could please explain it it to me. Thanks
The battery master cuts in if the engine battery gets lower than 0.7v I think than the leisure battery. A lower leisure battery means the voltage is slightly lower so won’t cut in as soon. There is also less there to supply power to the engine battery.
