A wall mounted electric heater ?
bognor regis
Burstner Aviano 675G
10 years
H
Hi all
I’m fed up with our unreliable Trumatic C which provides loads of hot water but cuts out on gas despite a new pcb and regulator. Most of our winter camping is on ehu, so I’m thinking about a wall mounted electric radiator instead of the wheeled one in the picture. The socket is available and I’m aware of variable supplies on aires and campsites. Van is an A class Burstner Aviano 2008, so quite a bit of space. Or should I continue to try and get the Trumatic heating going ?
I doubt if you will have enough space to mount a panel heater large enough to be effective.
When working properly Truma Combi's are very good so probably worth persevering with it.
Would not think the walls in modern motorhomes would be strong enough to hold a decent heater.BUSBY.
1000w fan heater is much lighter and faster to warm the place up.
I wonder if one or the other could double used, a fan heater as a hair dryer,or the reverse? :giggle: Somewhat tongue in cheek.
Mike.
