A Sickly Sweet Video Of An Identical Van To Mine...
Always makes me think... How can a cupboard with a shower in it be called a BATHroom ?
A bathroom has a bath in it.. ( unless you are a septic in which case it has a toilet bowl.. which brings in to question HOW they bathe in it ?? :-) )
It looks very similar to ours!!!!1991 Fiat 2.5 non turbo
It is much the same size, ours has a portuguese made fibreglass body---- so far everything seems to work ? But it doesn't have a heater so we are planning on fitting a Chinese diesel one----- I suppose they didn't think a heater was necessary in portugal!
Only been able to have a short run out so far and it appears really good for what it is------ power doesn't quite match our Cummins 5.9 but it is fine to do what we want!!
'LEZ compliant' - yes everything under 3.5t is, no matter how poluting! DOH!
No it is exempt under 2,5T & dependent on the year between 2,5T & 3,5T. Mine was exempt being under 2,5 T That would be also as it appears to be on the peugeot J5 or Fial Talento(Ducato) ultra short wheel base, as was mine.
  • Informative
Reactions: JJ
A bathroom has a bath in it.. ( unless you are a septic in which case it has a toilet bowl.. which brings in to question HOW they bathe in it ?? :) )
A Bathroom can be defined as 'a room to bathe or shower in' ........ 🙂
Surely yours is longer than 4.9 metres...
(I really like the Andrade motorhomes...)
JJ :cool:
It’s 5.9 including the bike rack. Falls within 6 metres so can do the Norwegian coastal ferries without costing an arm and a leg. Yay!
As far as a dictionary goes yes... but not for me !! And that STILL does not explain what the yanks are doing in the bog !
What ever it is it CANNOT be hygienic !!
Yep. I had forgotten that older bit. Why do they make regs so complex.
