6kg Calor gas bottles (1 Viewer)
Jun 17, 2021
25
15
Bedford, UK
Elddis Impressa 115
On and off since 2008
Hi all, as a newbie, I am getting frustrated by the fact I cannot get a 6kg refill for my Moho. A stupid question perhaps, why can’t we use Flogas in the Moho, as there seems to be lots available. It would obviously have to have a different regulator. Just interested in the general view. Also is there normally a supply at motorhome shows for campers. Thank you.
Ivory55
6,017
14,534
North West Norfolk
Since Feb 2012
There is normally a supply at the shows. Flo gas is the same fitting, different bottles
M-J
Jan 15, 2019
2,647
6,300
Cambridgeshire, UK
Rapido 986F
Getting there!
Have you checked local filling stations, builders merchants and caravan accessory shops?
Took me a week to get one, 2 trips locally, first time no stock but found out their delivery days/times, went back and bingo.
May 7, 2016
7,288
11,782
West Sussex
Since 2003
Hi!
No questions are stupid, we all learn from each other. The pressure of propane is the same whether it comes in a Calor or a Flogas bottle so you regulator should be ok. Ivory55 says the fittings are the same too so should be straightforward.
Reactions: f6c
Jonno1103
1,336
1,482
Harrogate
F Line F70
We use 6kg Flo Gas, standard screw fittings. There's no difference between them and Calor.
Speak to them, set up an account and they'll deliver direct within 2 days of yours being empty. The bottles are also a bit lighter than Calor too.
I've also attached a link to their stockists around Bedford.
Jun 16, 2014
656
2,440
NOTTINGHAM
Autotrail Savannah
Almost a Newbie but not quite now.
We have the best of both worlds. 6kg flogas and 13??kg calor. Just swap pol connector between the two bottles (they are the same fitting as others have stated), IIRC the flogas bottle has zero deposit on it unlike the calor, Managed to obtain mine from the local dump.
Feb 26, 2012
528
368
coach
Motorhome since 2006 (caravanning 38yrs)
Word of caution.
Screw connection is the same for propane which matches the OP 6 kg but I believe there is a difference if using butane as there are different sizes of clip - on connectors.
kevenh
3,319
11,801
Thatcham
Compass C-Class
I'm a Progressing Newbie
Flogas has/had similar bottle shortages to Calor when I checked the other week 🤔
But at least there are more than one supplier options :)
Do they take each others empties for exchanges? :rofl:
edit: Flogas have a big list of other peoples bottles that are accepted. But oddly :) no Calor
Source
An FAQ question lower down on this page has Calor's acceptable 'other' vendors. But oddly :) no Flogas
206
256
hartlepool
Hi Top
Hit the road in 2014
have you tried your local council refuse yard, I gave one of the lads a 24 pack of beers for a 6kg bottle then went and got a refill.
Jun 29, 2015
3,493
57,747
Southampton
caravan (for now)
on and off since 1984
I bought a refill from Calor Southampton, but when I went to collect it, they had sold it😟 hopefully get one tomorrow.
