Minxy
- Aug 22, 2007
- 32,489
- 66,023
- Carthago Compactline
- Since 1996, had Elddis/Swift/Rapido/Rimor/Chausson MHs. Autocruise/Globecar PVCs/Compactline i-138
I bought this to put on our camper but before I fitted it we changed to a phone contract for our internet provision which won't take an antenna so is now surplus to requirements.
It is new and comes with a stainless steel L bracket which you can Sikaflex to the roof so you don't have to drill holes to fit the antenna itself (you don't have to use the bracket if you don't want to).
It has 2 x 3 metre cables attached with SMA ends but you can buy TS-9 converters very cheaply of Ebay if that's what you need for your MIFI.
Info below and on the attached spec sheet:
2G/3G/4G MIMO Waterproof Outdoor Puck Antenna LTE AntiVandal L-Bracket Plate
The CMO antenna is a 2G/3G/4G LTE MIMO puck antenna ideal for LTE applications requiring a low profile MIMO antenna for 2G/3G/4G and LTE fixed and mobile applications
The CMO is a 2G/3G/4G LTE MIMO puck antenna operating multiband frequencies, for example for 4G/LTE it uses 690-2700 MHz. A permanent, through-hole mount antenna, the CMO has two Multiband elements enabling MIMO operation in discreet, robust housing.
With peak gain ranging across the bands from 1 dBi to 3.5 dBi, the CMO offers an effective solution for mobile 4G and LTE MIMO applications offering support for 3G and GPRS services.
The CMO antenna is supplied with a wall mountable L bracket and is held in place with a robust locking nut. In conjunction with the gasket underneath, a waterproof seal can be formed ensuring that the antenna is suited to continuous outdoor deployment. The CMO antenna operates most effectively if it is mounted onto a metal surface, such as the bracket supplied. The mounting hole size is 20mm.
Supplied as standard with 2 x 3 Meter RG174 cables with Male SMA connectors.
