- 3,5 T speed limits
stoke on trent
relay lwb pvc
6 years
Am I Correct in believing a 3.5 T MH. has a limit of 70 mph on M/way and dual carriageway as my Garmin says 60 and I have programmed it for - ,3.5 T ?
Speed limits for under 3.5t motorhomes are the same as cars in the UK.
So, 70mph on motorways and dual carriageways.
Different for over 3.5t.
Richard
The Gov website is referring to 3.05T but a 3500kg MH would be 3.5T thus the 60mph dual carriageway 70mph motorway limit? Or don't I understand the difference between KG and Tonne?
1000kg=1 tonne
A vehicle registered as a motor caravan in the UK is a bit of an anomaly since it’s speed limit is dependant on its UNLADEN weight unlike other vehicles which are dependant on their max LADEN weight.
See here
So if a Motorhome has a max weight of 4.5t but it’s unladen weight is only 3t then the higher (same as car) speed limits apply. If it’s unladen weight is 3.5t then the lower (same as up to 7.5 van/truck) limits apply.
This is only applicable in the UK as most other countries are based on max weight.
With some of today’s poor designs and payloads it’s possible to have a max 3.5t van that is limited to the lower speeds by virtue of it’s unladen weight being more than 3.05t.
From the government website
Motorhomes or motor caravans (not more than 3.05 tonnes maximum unladen weight)30 (48)60 (96)70 (112)70 (112
Unladen Vehicle weight as described by the Gov website
The unladen weight of any vehicle is the weight of the vehicle when it’s not carrying any passengers, goods or other items.
It includes the body and all parts normally used with the vehicle or trailer when it’s used on a road.
It doesn’t include the weight of:
  • fuel
  • batteries in an electric vehicle - unless it’s a mobility scooter or powered wheelchair
So for Motorhomes or Campervans if you vehicle is below that weight when unladen then the same as a Car. Above that weight when unladen then the same as a car except 50mph in a Single Carriageway and 60mph in a Dual Carriageway.
In the UK the speed limit is not based on the revenue weight but the unladen weight which is not shown on my V5C, so it must be very difficult to police the lower limit. My CofC shows an unladen weight of 3015kg so I am not subject to the lower speed limits even though the vehicle is registered 4200kg.
Does anyone really think the DVSA/police are going to spend time checking speed limits/unladen weight when there is no easily accessible information? As it happens mine is quoted on my V5 as 3040kg so I'm not restricted to the lower speed limits, despite having upgraded the MAUW to 3850, which of course makes the whole UK situation a farce.
IMO the only time this would be taken into account is in the event of a serious accident or when the insurance assessor is looking for a way to avoid paying out.
  • fuel
Is that specified unladen weight for the vehicle or actual unladen weight as this would vary from journey to journey.
If the label attached to vehicle is
3500kg
6000kg
1-1850kg
2-2100kg
then what is the unladen weight with regards the law for speed limit, Is it 3500kg ?
3500kg
6000kg
1-1850kg
2-2100kg
The unladen weight is not shown on the vehicle plate and can not be calculated from it. As said above the 3500kg has no bearing on the UK speed limit applicable. I think you will need to look at the Certificate of Conformity or perhaps the original specification to find out what the unladen weight is. The unladen weight should not vary from journey to journey.
This message is sent out to all of those on here that have a panel van conversion.
Could I suggest that you check your V5C and ensure that it has the description "Motor caravan" therein.
If that description has not been changed by the convertor or subsequently, you run the risk of being stopped by the Police or, even worse, 'Flashed' by a roadside camera when travelling on a dual carriageway.
This is because, unless your vehicle is registered as a motor caravan and it has a G.V.W of more than 2000Kgs, the vehicles speed limit on a dual carriageway is 60mph and not 70mph.
Thank you for your reply. Please excuse my ignorance on this but how do I find out what the unladen weight is when it does not seem to be on the V5C. This refers to a panel van conversion.
Thank you for your post but as mentioned in my previous post, how do I find the unladen weight.
Virtually impossible, manufacturers do not publish unladen weight your Certificate of Conformity will only show MIRO which is not the same.
It's not the Unladen weight in this case. It's the Gross Vehicle Weight.
Previous comments relate to another issue entirely.
This is yet another trap that it is possible to fall into.
Yet more to confuse me. Is the GVW the same as Revenue weight
Your comments are based on the vehicle being a 'Motor Caravan' If the vehicle is not a 'Motor Caravan' the speed limit is based on the GVW. If it (say a a
No. The Gross Vehicle weight is the weight that the van would weigh, fully loaded BEFORE it was converted. I can tell you this. Son No.2 drives a Peugeot van for a Utility Co. It is substantially smaller that the Fiat Ducato, Peugeot Boxer, etc. It has a GVW in excess of 2000Kgs and thus has the lower speed limit on dual carriageways.
ALL!!! the panel van conversions I've ever seen have a GVW over 2000Kgs and thus fall into the same bracket UNLESS!!! they are registered as a Motor Caravan on their V5C's
Sorry, I don’t really know. My Hymer came with a Certificate of Conformity which shows a Masse des fahrbereiten which I have taken to be the unladen weight, as well as the MIRO. The Price List/Technical Data for the Carthago I have on order gives unladen weights as well as MIRO but I have to add the weights of factory fitted extras to both these figures.
Okay, apologies to the OP for hijacking the thread and thanks for all the replies but I am still confused.
The question is, how do I determine the speed limits when I can't find or work out what the unladen weight is of the vehicle and how does the DVLA work it out. The weight recorded on the V5C is the Revenue Weight which matches the weight on the vin plate.
Go and weigh it
EMPTY
Yes, that would be a good place to start. If under 3050kg (no driver or passengers, all tanks empty, no food, no bedding, no pots or pans, no nothing) you can be confident using the upper speed limits. If over then keep to the lower limit (after allowing for the weight of any fuel in the tank).
At least if you weigh the van empty you will /should get a print out as evidence to show police should you be stopped. I have Dethleffs plated at 3850 but well below 3050 so comfortable in doing higher speeds.
I would be interested to hear about anyone who has ever been prosecuted in the UK for driving at a speed higher than the maximum specified for a motorhome over 3050 kg unladen weight and below the maximum specified for a car.
If you are threatened with speeding , take the van to a weighbridge and have it weighed, AFTER removing EVERYTHING of weight Leisure Batteries, water, fuel, passenger seat table (on Hymers) all cushions and mattresses everything form the cupboards , cassette, TV, absolutely everything from the garage etc THEN get the ticket and put it to a court. if it below that weight they will have to accept the rules as written. I would remove everything, everything, and it would be below that limit. Do not forget the awning either as that is heavy my passenger seat is 50 kilos by itself.
It would be worth it to avoid 3 points and the fine, AND the insurance increase for being a bad boy.
Do you need to know this information because you're in a hurry to get where you're going? Just do 60mph...... or less, it'll be more economical anyway and you'll still get where you want to go, just a few minutes later. ?
But I would like to be able to do 60 mph legally on a single carriageway and not be restricted to 50mph.
Go and weigh it
EMPTY
I will do that but the DVLA must have a weight to set up their databases for speed cameras, well I assume they must.
I have found an email address for someone at the DVLA and sent off a request for clarification and received an auto response to say they will try and respond within ....20 days !.
It will be interesting to read their response, usually I find their replies to awkward questions of little help, they just quote the law and tell you it is your responsibility to comply. Let us hope you get something useful this time.
I suspect the DVLA knows that using unladen weights for speed limits on motorhomes presents enforcement problems. A year ago I drove passed a speed camera van at nearly 60MPH on a single carriageway road in my over 3500kg motorhome and have heard nothing from them. I very much doubt they even bothered to check out my unladen weight, which they might well not have access to anyway. They were probably getting plenty of 60+ hits on cars to make their day worthwhile without digging in difficult areas.
