Perhaps look for 12v chargers.Hi I have a mh with solar panel on but want a 240 socket for the odd gadget when not on hook up. Best way to do please.
If that's an evaporative cooler you might be OK, but otherwise "no chance" evaporative cooler you fill with water. With just a single 110 lead acid you would have to be really careful with an inverter.Need to look at battery but think its 110ah none lithium. Got a small portable air con unit that plugs in dont know the wattage
You can get 12v to 240 v invertersPerhaps look for 12v chargers.
Yeah they come in handy for the odd usage. Bit expensive for what they are but are certainly usaeableWhile realising I will be shot down in flames for mentioning it I have an ecoflow mini that will power the hairdryer and occasional low wattage kettle. Requires no installation and will charge up in no time when you do have ehu.
How much was your invertorGet an inverter or a generator, how many leisure batteries have you got? I've got two 100 ah and a 3000W Pure Sine Wave Power Inverter lets SWHTBO dry her hair
Its a water fillIf that's an evaporative cooler you might be OK, but otherwise "no chance" evaporative cooler you fill with water. With just a single 110 lead acid you would have to be really careful with an inverter.
Careful why?If that's an evaporative cooler you might be OK, but otherwise "no chance" evaporative cooler you fill with water. With just a single 110 lead acid you would have to be really careful with an inverter.
I paid £102 for it, was on offer, now £139, I hard wired it in with some 6mm cable as the ones that came with it weren't long enough.How much was your invertor
How muchI got a 300w for sale well it will be when I get round to it that I took out to put the 3000w in
Why would you convert 12v to 240v to charge a 40v (for instance) laptop when there are many 12v adapters available.You can get 12v to 240 v inverters
I have a laptop needs 140A beyond capabilities of a 12V socket. But agree, if possible look at 12V charging, or USB charging for gadgets as much more efficient.Why would you convert 12v to 240v to charge a 40v (for instance) laptop when there are many 12v
Most smaller inverters will have a 240V socket on their housing. Ideal to keep simple for one connection gadget at a time.I need 240v only 1 socket
Many electronics, especially if it has any form of chip to control it, will need a pure sine wave inverter.
For small, not heat producing, gadgets including laptops, e-bike battery chargers and simular a 300W output may be OK.
If you are running something like coolers, heater, toaster, kettle, hairdryer, microwave these should all have labels showing their wattage. Allow a little bit more for safety, especially microwave that can have a sudden start up current.
Now look at battery. This gascs maximum charge/discharge rate, often the C rate. Exceed that and the battery won't last long. Batteries also have a storage capacity and for lead acid types only 50% usable else the battery dies quickish. As above inverter pulls a lot of current at 12V to give 240V, so if you have 100Ah lead acid battery, 50% gives you 50Ah for inverter, lights znd anything else and even a small 25A @ 12V load wouldn't give you 2hours draw if you are needling other things too. the first one thats
You're the first to explain properlyMany electronics, especially if it has any form of chip to control it, will need a pure sine wave inverter.
