240, mains wiring on a 12 volt system/supply?????
old-mo
Extra Special
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Just read another thread =
Just wandering why not use 240 wire..???
Not anticipating doing any wiring now or in the future, just curious why you should not use mains wire..
To my little knowledgeable brain I would have thought it would be safe..... being far heavier than 12 volt wire..
As said... Just curious.... :)
If by "mains wire" you mean twin and earth, then it's NOT a flexible wire. It's meant to put into you wall or whatever and not be wiggled or shaken or thrown about. What is needed in MHs is multi-strand wire. This is able to withstand shaking etc. Obviously the more strands in the wire then the greater the current it can carry.
We had a Conway folding camper. Previous owner had wired it with twin and earth which the dealer removed and replaced with flexible 3 core cable.
but presumably the wire is going to be fixed in a motorhome and not moved.
Mains cable and flex uses better insulation than 12v wire adding unnecessary weight and bulk. The copper inside needs to be much thicker for 12v for any given load in Watts. For example 50W at 250v will cause the supply cable to carry 50/250 = 0.2 Amps but 50W at 12v is 50/12 = 4.2A
Motorhome converters without exception use flexible cable for mains wiring because the mounting surfaces are subject to vibration in a moving vehicle. For the same reason all vehicle low voltage wiring in any type of vehicle uses flexible, stranded, wire.
Looking back at the quote in the OP there is a basic mistake there for starters, never mind the need for multi-strand cable. He quotes the cable as being 30amp. Standard mains cable wiring for sockets is 2.5mm. That has a rating of 20-23 amps, not 30 amps depending on where it is. While consumer unit circuit breakers are 30 amps, there is always a ring main, so the electricity can flow either or both ways from the consumer unit to the sockets, thus doubling capacity.
To get 30amps from a single cable you would need to use either 4mm or 6mm cable, and anyone who has handled either of these will know it is hefty stuff.
Just looked at the other thread he doesn't make it clear but it does look like he has used solid (T&E) so I would change it for flex to avoid future problems from vibration.
It would have to be a hell of a vibration to break a twin and earth cable wouldn't it. I think my fillings would come out first.
Still, it's theoretically possible I suppose ?
More likely to vibrate out of connectors that aren't designed for it.
But what it is fixed to will vibrate, ie move and that is what will do the damage. Suitable flexible cabling is required what ever the voltage.
apart from flexibility, cable mm2 15amps at 240v AC in a ring main is different to 15amps at 12v DC in a non ring main circuit. Its a lot smaller, because of the "higher pressure of voltage" at 240v
Its also not practical as most mains wire is twin and earth in the same sheath and has the same 3 colour code, not good when trying to connect different circuits. Imaging fault finding, and the wiring diagram....!!
Solid copper wire 'work hardens' with vibration or constant bending and effectively becomes brittle, that's why it breaks.
when we wired ours up we used orange artic hookup cable for both sides , is that bad, must say there isnt a lot of it
Technically yellow arctic cable signifies 110v, blue arctic is for 240v, hence why the EHU connectors are blue.
The only difference with mains flex and low voltage flex is the insulation standard, I use whatever I have around.
So do the people who built my Le Voyageur. A lot of the 12v wiring is in 3 core mains flex with the yellow/green chopped back to the sheath - except where, in a couple of cases they needed 3 wires. Like you I use mains blue and brown for +12 and 0v respectively - my last Hymer used those colours - but I draw the line at twin & earth flex still in an outer sheath for 12v. Apart from anything else it takes up a lot of room in trunking or conduit.
