2020 Fiat A Class Passenger Door Not opening from outside (1 Viewer)
tattytony
182
163
Taunton Somerset
Dethleffs
Does anyone in the know can tell me what i might be able to do to get it working again, the handle is loose great for potential theives to keep them out but i do need it working.?? TIA
Oct 12, 2009
10,837
23,998
A Class N+B Arto 69GL
Since 2009
Since it is an A Class rather than a C class it would be useful if you stated the Manufacturer, Model and year.
Upvote 1
Jun 12, 2020
45
63
Cumbria, UK
Pilote Galaxy G600G
Since 2015
If the outside door handle is loose and won’t operate the door catch mechanism it sounds like a disconnected linkage between the handle and catch mechanism. Does the inside handle still work properly?
tattytony
tattytony
182
163
Taunton Somerset
Dethleffs
I am a little lost here what can i remove ?
Lenny HB
54,133
152,854
On the coast in West Sussex
Hymer B678 DL
If there is not a cover around the lock on the inside you will have to take the internal door panel off. It will probably be a bent or broken linkage it's common on Hartal doors.
1,838
2,287
You might try taking the inside handle off carefully and see if the link bar that goes from the outside handle to the catch has come off it did on my Burstner. If it’s like our thee trim is a bugger to get off. Do it with the door open and be carefull not to lose the inner door link or you wont be able to open the door again, we ar lucky we have a garage at the bottom of our garden the van lives in so I took the bar it locks onto off the what would be the B post whilst I did mine,
tattytony
tattytony
182
163
Taunton Somerset
Dethleffs
Door panel has one screw at the bottom and when removed the panel stays in place firmly so i think i will leave it to the dealers unless someone has a Globetrotter XLI and know exactly how to get the panel off.
Thanks for everyone's help so far.
8,618
20,472
Shrewsbury (sometimes)
N&B Clou Liner MAN
You might find that the moulding fits into a channel on the body of the door, the way to get them out is to carefully push against the sides untill one of them springs loose, then work the others out. Once out it will probably be pretty obvious what's wrong.
517
1,546
Portugal
Dethleffs Globetrott
Newbie
We own a Globetrotter and the same happened to us a couple of years ago the day before we had a scheduled dealer visit, so they fixed it for us.
May I suggest you try either the:
Dethelffs Owners Club https://www.dethleffsowners.co.uk/ which costs £15 to join
or
Dethleffs Owners Club UK Group on facebook?
Hopefully, someone on there should be able to assist you.
45
63
Cumbria, UK
Pilote Galaxy G600G
Since 2015
The passenger door internal panel on our Pilote Galaxy is held in place with only two screws. A rubber sealing strip going completely around the join between the inner door panel and the door itself then holds it in place when the screws are removed. Possibly there something similar on your?
