2011 3L Multijet 160 Generic Amber warning Triangle on instrument panel. (1 Viewer)
May 25, 2024
Burstner Ixeo 585t
I was wondering if anyone out there has a similar model to my Ducato.
I am trying to find out if the Amber warning triangle is supposed to come on when you turn on the ignition and then go out after the engine is started or whether it only ever comes on if there is a fault?
MisterB
6,259
14,152
Adria 670 SLT
google search answer below, perhaps it just needs some oil as opposed to the sensor?
What is the yellow triangle with exclamation mark on Fiat Ducato?
Anybody here experienced the generic fault warning light? It's the amber triangle enclosing an exclamation mark. Mine's been lighting up intermittently so took into Fiat Professional dealer today. Turns out it's a faulty oil level sensor, a relatively cheap part, but 6 or 7 labour hours to fit!
J
May 25, 2024
Burstner Ixeo 585t
Thanks, but at the moment I am just trying to establish if my Triangle warning light is working as specified. Hence the original question.
Dec 2, 2019
4,227
9,473
South Lincolnshire
Rapido 7065+
Broken most bits now
There is no amber warning triangle when I turn on the ignition on our 2011 3.0 160 Multijet (Comfortmatic) so it sounds like you need to have the engine codes read to see if there is a problem or not..
J
May 25, 2024
Burstner Ixeo 585t
Hi Thanks for this this just what I wanted to know and has put my mind at rest.
I recently had a problem with what transpired to be the oil pressure switch/sensor.
The warning triangle was intermittently coming on and then going off.
I had the sensor replaced last week the Motorhome was handed over to me with the engine running and I drove it straight back to the storage facility that we use. To get in I had to open a gate, while I was doing this I switched the engine off. When I got back in to restart it I switched the ignition on I noticed that the triangle symbol didn't appear on the control panel, for some reason I thought that it came on and then went off when the engine was started (like the engine symbol), so I thought the garage repair had not been done correctly.
So your response has confirmed that everything is as it should be. Thanks.
BTW, we have the same model with (Comfortmatic) very nice to drive however a couple of times we have had the gearbox overheat symbol come on. Both times after filling up with both water and diesel abroad and going up steep hills.
Dec 2, 2019
4,227
9,473
South Lincolnshire
Rapido 7065+
I've never had the gearbox overheat problem although I've had the clutch overheat message when trying to negotiate a very tight and narrow uphill hairpin bend in Italy. The nearside wheel kept loosing traction and spinning even on the dry tarmac in 2nd gear with featherweight throttle. I had to be on full steering lock to get myself out of the self inflicted sat nav blooper. The encouragement of the locals didn't really help..
