2001 fiat ducato 2.8 jtd gearbox (1 Viewer)
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
On the end of gearbox by driveshaft there is a black plastic cover 6 or 7 nuts or bolts holding it on i have slight oil leak from it think the gasket needs replacing anyone know what the plastic cover is called
TheBig1
17,630
43,280
pass but I would remove the plate, clean the gasket, then reassemble using the gasket and gasket sealant
M
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
Gasket looks shot i just want to get another gasket but dont know what part is called cant find it online either
TheBig1
17,630
43,280
then you need the chassis number and the gasket and go into a fiat garage and they will have or order one
The Nomad
1,052
1,064
Wandering in Europe
Overcab
Many years
It's the gearbox end cover.
Inside it is the 5thgear cog which was added in a sort of satellite compartment on the end of the previous 4 speed box.
Ready made gasket is still readily available, or you can use gasket sealant.
M
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
Thanks for that didn't realise it held 5th gear inside cover
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
If it is the end cover where fifth gear is housed then the cover itself is steel and there is no gasket, a bead of sealant is used and they almost never leak.
D.
M
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
D.
I'll recheck cover definately leaking it looks plastic like the timing belt cover but it is quite wet here at moment so will check later today
M
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
Post a picture, says 1000 word's.
:party::party::party::party::party::party::party:
Ok photo enclosed not very good but that is the part that is leaking and as dave said it is metal looks like a gasket on it but maybe it is old sealant hanging loose will remove cover when it stops raining and have a look fair bit of oil on gaiters as well so will have to wash them off as well
Jul 13, 2008
3,739
3,872
Low profile
A picture says a 1000 words? Unfortunately yours says 10. ;)
M
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
Picture is crap i know very wet here but the black bit is the metal housing for the 5th gear which has leak on joint soon as it stops raining i will remove cover
Jul 13, 2008
3,739
3,872
Low profile
Check for any fine metal particles in the oil and try and inspect the 5th gear and it's syncromech while you're in there.
M
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
Apparently 5th gear fails or breaks however you want to put it but yes i will check for damage or metal and then top up with oil but others advise is more than recommended by fiat just got to figure where to top up additional oil probably remove reverse switch
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Fifth gear doesn't fail on your gearbox, that was the previous generation.
D.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
You refill through the breather on top of the box, there is no level plug. Drain the oil before you remove the cover then when the job is completed refill with the correct amount of the correct oil through the breather.
D.
Oct 12, 2009
10,663
23,655
A Class N+B Arto 69GL
Since 2009
The gearbox was redesigned in 2001 from memory, if reverse is left and up then it's the later box that doesn't suffer fifth gear failures. If reverse is right and down then it's the earlier box that has been known to suffer.
D.
My Ducato was first registered in UK on 11.04.2003 so may have been with dealers for some time unless it was a customer order and left N+B a while before that. It would undoubtedly have been built by FIAT in 2003.
It has 5th left and forward so is the modified box and VIN ends with 7165373.
I have had the oil level increased from the manual stated quantityto what FIAT advised some time ago, but canot remember the exact quantity.
Geoff
M
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
Mine is 2001 on early box then and 2.7 lts to fill from empty is what people say
The Nomad
1,052
1,064
Wandering in Europe
Overcab
Many years
D.
Yep, early 2001.....although that was the change date for vehicle production. Given that a lot of Fiat based motorhomes sit on chassis cabs that might have been produced by Fiat very many months prior, it is possible that there are some large 2001 and even 2002 first registered fiat based motorhomes turning around with the early rather than later version box.
Feb 22, 2011
9,791
20,161
Newcastle under Lyme
Hymer B544 A Class
Since 2015
I think my 2003 is the later version then, reverse left and up, so do I still need to put more oil in than the 2litres specified ? I thought 2.7 litres was recemmended. It's on my list of jobs to do when the weather gets a bit better..
TIA
Oct 12, 2009
10,663
23,655
Since 2009
TIA
When I requested our garage (commercial ) to put extra in he agredd - not just for the money.
Another tip that is recommended is that although all gearboxes are 'splash lubricated', that one does not engage 5th till the oil is warm - I usually do not do it until the engine water temp nearly reaches operating temp.
Geoff
M
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
Got 5th gear housing off gasket can be seen which looks good no metal in housing either drained oil off probably lucky if there's 2lts in there so going out to get some oil and gasket sealant to use with seal which looks good.
Can find reverse switch thought breather was close by slightly behind but cant find it where in relation to reverse switch is breather
