Unless your hot water and/or heating are gas only or are only running on the gas, as per a fridge.You will probably trip the RCD when you put the kettle on, if you also have your hot water boiler or heating on, unless you have a low wattage Kettle, which I am selling if your interested.
Would an RCD trip? I thought the RCD was tripped by leakage not overload. I would expect the sites 10A circuit breaker to be the first thing to operate.You will probably trip the RCD when you put the kettle on, if you also have your hot water boiler or heating on, unless you have a low wattage Kettle, which I am selling if your interested.
Yes , I think you are correct, but what do I know!Would an RCD trip? I thought the RCD was tripped by leakage not overload. I would expect the sites 10A circuit breaker to be the first thing to operate.
They will trip on overload as well.Would an RCD trip? I thought the RCD was tripped by leakage not overload. I would expect the sites 10A circuit breaker to be the first thing to operate.
That would be interesting to see.I have a 3kW kettle and have "never" had a problem even on continental sites, although I usually take care with my power calculations when the available current is low.
Gordon
Most German sites are 16 amp these days, in my experience.Wait until you go touring Europe and you only get 6amps.
I thought the amps were just a power rating, not a tripping point.They will trip on overload as well.
If they didn't trip why so many different current rated RCDs....
32a 30ma for ring mains,
45a 30ma for electric shower and instant water heaters.
63a 30ma for consumer unit main switchs.
I hope you complained bitterly, that is outrageous. I would have insisted on a full 60Euro refund.Electrical supplies don't always do what it says on the can: one stellplatz in Germany had €0.23 in credit when I arrived and over €60 in credit when I left, despite never putting a cent in!
Or 3a on some Italian sitesWait until you go touring Europe and you only get 6amps.
So if that's the case make them all 1000amps, it won't make any difference if its not a trip current.I thought the amps were just a power rating, not a tripping point.
Normally 220 - 240.Just looking on the Internet and found amps=watts/volts. I know I'm asking a silly question but are the electric hook ups 240v?
I think it is just telling you the maximum current it can safely handle before it melts or burns out. The MCB looks after overload, the RCD detects leakage.So if that's the case make them all 1000amps, it won't make any difference if its not a trip current.
