12V Telly lead??? (1 Viewer)
acornjudi
Barnsley
Compass Avantguarde 100
I'm new
Hi, we have just enjoyed our first weekend in our motorhome at The Shady Oak, Beeston, Cheshire and had a fantastic time! I just need some help with my telly! I bought a Techwood 16" TV & DVD from Morrisons (£79.00) Great picture, decent sound, really chuffed with it for the price. We were hooked up to electric so that was ok, but I'm wondering what lead I will need to run it off the leisure battery (I don't want to blow the whole thing up). In our motorhome we have a 2 flat pin (kind of parallel) socket next to the ariel socket. I've looked on t'internet and can get my hands on a plug to fit this. The lead that goes into the back of the telly is a 4 pin round thing. I have also seen these for sale, with a lighter socket plug in at the other end. My question is, if I buy one of these leads, would I simply be able to cut off the lighter plug in and wire up the 2-pin plug to fit nicely into the socket, or do I need an inverter or something else? Hope someone can help!:thumb:
Dec 6, 2011
11,602
25,459
South Wales
Coach built Adria
does your TV have a step down transformer in line from the mains plug to TV?
if not you will need an inverter
11,932
9,097
Hi I am ALMOST certain Techwood 16" TV & DVD are not 12v.:Sad: Does it say 12v on the back ? I ask simply because the plug you describe is usually one of the two types on a 12v er :Smile:
terry
GJH
29,450
38,827
None, now sold
2006 to 2022
If it is the 16911 model like [ame="http://www.amazon.co.uk/Techwood-16911-16-inch-Ready-Player/dp/B005T6FI9I/ref=pd_sxp_f_pt"]This One at Amazon[/ame] then it should take a 12 volt lead like [ame="http://www.ebay.co.uk/itm/160630930981?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649"]This One[/ame]. Your user manual should tell you whether it will do so or not.
As Terry says, though, model numbers can't always be relied on and may be dual voltage from one supplier but not another.
If it does turn out to take 12 volt direct you can change the plug as you suggest but make sure you wire it up (+ & -) correctly.
callumwa
4,110
4,480
Tyne & Wear, sometimes..
Hi, we have just enjoyed our first weekend in our motorhome at The Shady Oak, Beeston, Cheshire and had a fantastic time! I just need some help with my telly! I bought a [HI]Techwood 16" TV & DVD[/HI] from Morrisons (£79.00) Great picture, decent sound, really chuffed with it for the price. We were hooked up to electric so that was ok, but I'm wondering what lead I will need to run it off the leisure battery (I don't want to blow the whole thing up). In our motorhome we have a 2 flat pin (kind of parallel) socket next to the ariel socket. I've looked on t'internet and can get my hands on a plug to fit this. The lead that goes into the back of the telly is a 4 pin round thing. I have also seen these for sale, with a lighter socket plug in at the other end. My question is, if I buy one of these leads, would I simply be able to cut off the lighter plug in and wire up the 2-pin plug to fit nicely into the socket, or do I need an inverter or something else? Hope someone can help!:thumb:
if it is the same as this one (16911) it is 12V.:thumb:
[ame="http://www.amazon.co.uk/Techwood-16911-16-inch-Ready-Player/dp/tech-data/B005T6FI9I/ref=de_a_smtd"]http://www.amazon.co.uk/Techwood-16911-16-inch-Ready-Player/dp/tech-data/B005T6FI9I/ref=de_a_smtd[/ame]
So just wire your plug up with correct polarity.
Check the polarity of your 12V supply with a multimeter if necessary....
then Bob's your father's brother...:thumb::thumb:
Vlad The Impaler
1,633
2,227
Rutland
Since 2012 but longer in my dreams
12v tv
Bought the 19" tv DVD combo,as mentioned by Terry the other week,from ASDA .All I did was bought a 4 Pin to lighter adaptor cut the end off and wired to 2 pin plug in Motorhome.So simple to do just 2 wires and works a treat.
Cheers Terry !
43,337
49,540
same predicament with my temporary bedroom TV....i cut off the original lead and wired to a fag lighter plug.
it too has the round 4 pin plug on the mains lead via the black brick transformer.
the four pins are two positive (12v) and two negative.
you MUST get them in the correct order or you will blow the TV.
when/if you cut off the lead from the black brick you will find only two wires...positive and negative.......both pos pins go to one wire and both negs go to the other, connected together pos to pos and neg to neg within the plug.
the pins are marked + & - but very hard to see so check which is which with a volt/multimeter, with the box plugged in, BEFORE cutting off the lead then, after cutting the lead off, use the ohms/continuity function to identify the pos and neg pins to their corresponding wires.
double check everything as you only get one chance to get it right.
Vlad The Impaler
1,633
2,227
Rutland
It would have been easier to leave the supplied leads intact then if anything goes wrong with tv box it all up and take it back.If you buy lead with 4 pin and cigarette end cut off cig end and find 2 wires,simple!
43,337
49,540
Agreed....i never considered the guarantee as mine is an older tv. :Doh:
A
acornjudi
Barnsley
I'm new
Techwood 16911
Just double checked on the back and it is a 16911 saying 12v DC IN on the back! I'm going to send for a cigarette lighter lead off Amazon and rewire to fit in my 2 pin socket as suggested. Many thanks for all your replies, I'll let you know......:thumb:
