- Oct 13, 2023
- 42
- 34
- Autosleeper Warwick
Can somebody recommend a 12v Aircon for a 6m campervan. A rooftop one I guess.
Fire Maple Antarcti Stainless Steel Kettle 1.0 Liter Camp Kettle | for Boiling Water, Tea, Coffee, Freeze-dried Backpacking Meals | Portable for Camping Bushcraft and Travel £28.95
AMZCHEF Single Induction Hob, Portable Induction Hob with Slim Design of 4.45cm, 20 Power Levels and 20 Temperature Settings, Fashionable Black Glass Panel, Touch Sensor, Hour Timer, Safety Lock £38.99 It's a swamp cooler. They're ok when it's dry. But when it's humid, they are no more effective than a normal fan.Check out this…https://totalcool.co.uk/shop/activi...rtable-air-coolers/totalcool-3000-white-grey/
Designed and made in the UK…very effective and just a little bit cheaper than having air con fitted!
we bought one of them of Ebay, it is quite good if not a bit noisy. I did drop one of the tanks when frozen and broke it though !I got one of these from Aldi a few days ago. With a punt if it works if not it’s going back. Works on 12 volt usb
They are good at introducing lots of moisture and damp airCheck out this…https://totalcool.co.uk/shop/activi...rtable-air-coolers/totalcool-3000-white-grey/
I haven’t seen or heard of a roof top 12v version, but, there is a 12v model underslung, some in the USA have it. I think it originates from Asian market. There is a guy on Yutube documented a installation kit. Comes pre charged with gas.Can somebody recommend a 12v Aircon for a 6m campervan. A rooftop one I guess.
Like this one
DC compressors are the most efficient, once the cooling target is reached, they can throttle down the speed and reduce the power next to nothing. The above example will happily run on 350w but can boost to 1000w. Same as inverter AC.It's 12volts, but it's still over 1000watts. Which means a lot of battery.
They are marginally more efficient. But don't most compressors convert internally anyway?DC compressors are the most efficient, once the cooling target is reached, they can throttle down the speed and reduce the power next to nothing. The above example will happily run on 350w but can boost to 1000w. Same as inverter AC.
First motorhome we have had without cab A/CWe run a Truma ducted unit on the move, 240v
Only have 105 ah lithium (soon to be 2 x 105)
But
Victron 50amp B2B
Victron 50amp solar controller
Victron multiplus inverter
Eurena 430w solar
That is a good pointThey are good at introducing lots of moisture and damp air![]()
No they are usually ac motors with 2 windings, with start and run capacitors across the start winding to increase torque.don't most compressors convert internally anyway?
Good point, hadn’t really thought about that, though if it is very hot and the space has some ventilation I don’t think it will cause any damp problems.They are good at introducing lots of moisture and damp air![]()
So roughly 500 watts? Which is a pretty hefty load of you're sustaining it for a few hours off grid. But as you've paired it with a good solar setup, it becomes manageable. You'd probably still only be able to use it for the peak of the day and maybe a burst before bed though, as the battery needs to recover, no?This is with our engine off and a bit of solar. The A/C is on, freezer cycled off.
With engine running, we get around another 35amps
View attachment 902028View attachment 902029
But it’s about using it on the move for usSo roughly 500 watts? Which is a pretty hefty load of you're sustaining it for a few hours off grid. But as you've paired it with a good solar setup, it becomes manageable. You'd probably still only be able to use it for the peak of the day and maybe a burst before bed though, as the battery needs to recover, no?
www.zerobreeze.com
Where does the warm air off the condenser go? Does the unit sit in the window or something? Or is there an outdoor bit?I bought a zero breeze a while back - about £1200, works on its own battery for about 4 hours and keeps the van cool, can plug it into 240 on hookup, or charge on 12v to push it to around 8 hours on a 100ah leisure battery. Works really well. Also got a 240 trumma in the roof because it was an option from the dealer we thought wed use, but were rarely on hookup to use it.
Looks like they've come down a bit in price and theres a 2 battery option. Id highly recommend it, stock limited in the UK but I found mine on Amazon
ZERO BREEZE Mark 2 AC
ZERO BREEZE Mark 2 Battery Portable Air Conditioner, Just press the button and enjoy the cool air anywhere. Get yours at the ZERO BREEZE Online Store now!www.zerobreeze.com
I always think the pictures of these are really misleading. You have to have the exhaust duct fitted and pointing outside. They are a nice convenient size, but they aren't magic. It's a compressor AC unit, and roughly as efficient as any other. They still go through roughly the same energy to achieve the same effect. I think I would consider one over a roof mount though.I bought a zero breeze a while back - about £1200, works on its own battery for about 4 hours and keeps the van cool, can plug it into 240 on hookup, or charge on 12v to push it to around 8 hours on a 100ah leisure battery. Works really well. Also got a 240 trumma in the roof because it was an option from the dealer we thought wed use, but were rarely on hookup to use it.
I was going to ask that... surely you're just making the air moist which is the devil to a MH...They are good at introducing lots of moisture and damp air![]()
We use essential cookies to make this site work, and optional cookies to enhance your experience.
