12 volt Hair Drier (1 Viewer)
Nov 16, 2017
64
99
Worksop
Chausson 711
Since 2018
Can anyone suggest a good 12v hair drier one with plenty of blow
Riverbankannie
10,533
61,543
Bristol
IH 630 RL PVC
Before we were set up to use my proper hairdryer and ghd’s we just used to go on a site and have hook up.
As I only wash it once a week it’s no big deal . Though that would be if you need to do it everyday .
As for drying hair using vents .:Eeek::rofl:
I suppose that’s ok If you have short / thin hair. But if you have thick styled hair , nope, it won’t do.
I’d look like
Ha! Ditto. All those who say just let it dry naturally have NO idea.
6,872
7,992
Manchester
A class Hymer
Since the 80s
The only time you'll get any decent heat from 12v is when the melting 12v wiring sets fire to the van.
For us the solution was a big pure sine wave inverter!
Dyson hairdryer works well on a 1500 w inverter, with either the heat or blow tuned down one stop from full power
The power from the inverter is coming out of the 12v batteries, so it's not a battery problem.
You could make a 1200 watt 12 volt hairdryer, but it would take 1200/12 = 100 amps. It would need wires like heavy-duty jump leads, about the same size as water hose. And it would need one of those big Anderson connectors used for golf cart batteries. Nobody would buy it.
12 volts = 12 watts per amp.
240 volts = 240 watts per amp.
eddie
8,157
41,270
Taunton Somerset
RV
since 1989
Are you saying that nobody uses inverters?
Not every one has payload or storage issues so my large pure sine wave inverter handles 10 - 15minutes hairdryer use without any issue what so ever
funflair
19,350
30,242
Guisborough
MORELO palace
since 2012
NO he is saying that a 12v hair dryer is not limited by the batteries BUT by the cable and connectors, the fact that so many people run hair dryers off inverters is the proof that the batteries are capable.
Martin
881
1,679
Derbyshire, UK
Bailey Autograph
Since 2016
I bought my wife a 12v one when we got the MOHO and she turned it on for 5 seconds and then switched it off and said I’ll air dry it.
Useless
Silver-Fox
9,266
29,096
Cheltenham Spa
Rapido
im a not so newbie
Useless
I bought one before we went to N Z for our touring holiday.
The response was pretty much the same from SWMBO.
I thought I was being all clever like :rolleyes:
2,219
7,937
Horncastle, UK
Van Conversion
Since 2006
You can get gas powered straighteners if it helps.
Bought the Missus a set a few years ago for the van. She's an ex-hairdresser, and says they do the job fine.
Re hairdryer, we are going the inverter route. Her dryer uses 650w at the wall, on the setting she uses at home. So will draw around 55A at a guess from the batteries.
Not so bad for 5 mins. Far less than my Tassimo :)
Silver-Fox
9,266
29,096
Cheltenham Spa
Rapido
im a not so newbie
I wonder why no one has invented a gas hair drier like the straighteners?
Surely you would only be heating an element and have a small 12v fan to blow the heat. A rechargeable battery would take care of the fan.
Bet they would sell like hot cakes :D
2,585
8,773
Lincs
Globecar Campscout
There is a minimum 10 fold difference in power requirement. Hair straighteners & heated brushes are rated around 40-50W. Blown air hair dryers are a minimum of 10 times that & usually 20 times.
A gas powered hair dryer would be quite a scary beast! The air heating would have to be indirect as well - you can blow a blast of air across an electric element, but it would blow out a gas flame. So I imagine some sort of heat exchanger would be needed. It starts to be a tall order for something that should ideally be a hand held device.
Haitchjay
157
374
Hants/Wilts border
Pilote G740 fgj
Since 2016
I use my Dyson hairdryer with no probs. Recommended to me by another MH wife when away last year who let me try out hers in our van. Expensive but worth it. Not everyone would agree tho
Markncharlotte
22
34
Vw Crafter conversion
Bit of pipe off the hot air duct from the webasto diesel heater
Happy days
