- Feb 24, 2013
- 13,090
- 101,509
- Hymer S800
- not long enough
It would surely be easier for the merc dealer to drag a new wire through from the D on the alternator, which has power, to the Post under the seat where the power needs to be but isn't, rather than try to find what would appear to be a break in the existing wire.Phase 2 today, still not fixed but I am trying hard to pick the positives out of the trip
Been to a Reich expert thinking the fault must be there,
I now know I have a Reich 2 box, which is good news apparently, much better built
I also now know the Reich is not getting any input from the Mercedes side of things
Usefully it would appear the E + P pick up their own input directly from the chassis, as Martin describes above and Mick confirmed when I rang him for help today
What a top man he is, conversation went something like
'hello David, what can I do for you'
'Blimey Mick amazed you still have my number over 3 years since fitted, do you only keep the bad ones'
'no I keep any mobile number given to me, just in case'
'do you remember my job?'
'Hymer Mercedes, E + P and Air, bugger of a job'
'very impressive Mick'
we hadn't been able to easily see the connection under the seat, Mick described it like he did it yesterday, we could then confirm there is no voltage getting to this post
now either I didn't explain what I wanted well enough to Mertrux, or they didn't listen, either way they didn't do what I hoped. I have rung them back to explain that I have now spent a tank of fuel and paid 2 hours labour to confirm the voltage they assured me was present isn't where it needs to be. They have now confirmed they only checked it at the alternator
so phase 3 is right back to phase 1, back to Mercedes on Monday for them to find out where the signal voltage is going
I do know I don't need a new Reich box or alternator, so hopefully only time to find it now, unless there is some other component that might control the signal, even if there is hopefully not too expensive when found
Turbo boost valve sounds a possible candidate for lack of power, if there is one fitted on the V6 David.
How’s the van driving now David?
Looks like progress David, I can't imagine the front brake calliper was "very seized" as you should/would have picked it up driving or smelt the brakes getting "hot"
Long bolts in short holes, thats a bit basic thought Mercedes might have managed to get that right
Any all good.
Martin
Have you had the bill yet?Just sat in reception waiting to pick it up now
You might need to stay sitting down.
Did they show you where the relay is for next time ?
I haven't actually tried them, but am 99.9% sure they will
Go on man, give them a go. We need to know.I haven't actually tried them, but am 99.9% sure they will
...but do your E+P jacks deploy!
I'm pleased to see that you weren't "stung" David.
Cheers,
Jock.
