- Feb 24, 2013
- 13,090
- 101,509
- Hymer S800
- not long enough
just arrived at an overnight stop, luckily on 2 counts we are not too bad for level and the Jacks will not come down
It could be worse they might be down and not go up
we have had a couple of odd issues during our three years ownership where odd things happened, in all cases resolved by removing the main fuse count to 100 put back in and all has been OK
but not this time the symptoms are we get a quick triple flash of the green LED on remote then it goes out, tried a new battery exactly the same, tried the wired hand set got the same, removed main fuse, counted to probably not enough, put back all flashes but still same as above, but once pressed once the second time the LED does nothing
pulled fuse counted to 100, went for a walk with Lola, put back after probably 5 mins, reset, all lights flashed etc but still same as above
we have engine running and hand brake on as is required to work ours, it is now too dark to easily see in the locker outside and think I am just going to think myself lucky they are not stuck down then call Mick at SAP on Monday
Just wondered if anybody has had the same and got a quick (no tools) fix I could try
