Gaslow filler hole on Rapido V 56 (1 Viewer)
Greenacres
82
13
Stoke on Trent
Burstner Travel Van t620
13 years since retirement and many younger years as a Hippy in a VW conversion, roaming the Greek Is
Is it possible to use a Gaslow tank in a Rapido V 56 panel van.
The small seat in the doorway houses the gas tanks but I have been told that the filler hole would have to be inside the van on the side of this seat. Please could I have advice on what to do as just putting in 2 propane bottles would not last our trip even with time on hook up.
I don't fancy the smell and possible dirt/ safety of stopping at a garage for LPG and opening up the van. Thankyou
Feb 16, 2013
19,734
52,021
uttoxeter
ambulance conversion
50 years
If you are in stoke ,why not nip down to towtal opposite the Brit, they will soon tell you:thumb::thumb::thumb:
bobandjanie
8,161
15,796
Javea, Spain
Pilote V600g
Hi, we have the Rapido V53 van, and have 2 x 11kg aluminium refillable bottles, we have had Gaslow but changed to the lighter bottles on our last motorhome, then swapped them to this one. :thumb:
Have you looked at Gas it they are the same bottles just red instead of yellow. ::bigsmile:
Our gas locker is at the rear, and I took the filler pipe through the floor and its at the rear of the van, in your case you would take it through the bottom of the gas box and put one of these from gas it near your step. :thumb:
Here: Broken Link Removed
:thumb: Bob.
Minxy
32,651
66,541
E Yorks
Carthago Compactline
... what numpty told you that! That is just plain stupid! :Doh:
Below is your locker set-up so I'd do as has been suggested and get the small Gas-it one and stick it next to the step, it would look something like the other photo below from the outside.
43,329
49,444
installing the filler inside the van will cause problems at the filling station.
Even though you would be filling correctly via the proper filler It could appear to the pump attendant you could be filling standard calor bottles with an adaptor which is forbidden in more and more petrol stations.
A longer hose and filler on the outside panel is the way to go.
Greenacres
Greenacres
82
13
Stoke on Trent
Chaser you were right about Towtal. They have explained what they intend to do so Smiley Rapido will get her Gaslow after all. Thanks a bunch and they are only just up the road from me.
sadlonelygit
155
95
forest of dean
Rapido
since 1975
IIRC it is illegal to have a filler in the habitation area of the vehicle.
didn't stop my local stealer fitting one in our old hymer in the map locker by the passenger!!!!
