Electric heater (3 Viewers)
Jamwitt
630
367
Chandlersford
4yrs
Hi we going to setthorns on the 27 dec in the new forest as we will be on electric hook up want to take small electric heater,as we don't what to trip out on hook up wandered how to work out amps,the heater we might take 2000 watts :whatthe:
43,331
49,469
2000w / 230v = 8.7 amps
a couple of 700watt oil radiators would give a better heat distribution...one at the front and one at the back
if possible stand oil rads on a tin tray in case they start to leak.
not a common occurrence but always possible
Jamwitt
Jamwitt
630
367
Chandlersford
4yrs
Thanks for info papa John didn't think that would be so many amps :Smile::Smile:
oldun
747
162
St Neots
VW Campervan
Since 2001
Take a small (750W!) panel heater or a similar sized tubular heater - they cannot leak.
Apr 13, 2012
5,545
18,775
Mobilvetta Euroyacht
1996, then break 'til 2011
Used our van all last winter - 700w heater on its own wasn't enough (well insulated van).
Oil-filled 2000w was more than enough, electric blanket was great for warming up the bed ! - but not used at the same time !
CarolynandMike
108
129
South Wales
Liberty
since 2009
We're using an 1800 watt Delonghi heater very kindly donated by Salopian on the Marjal meet. We're using it on half power; it is more than adequate for temperatures around 5-6 degrees which we have had some nights and mornings since being out in Spain. We haven't tripped any electric supplies with it including a 6 amp ACSI site and run it in conjunction with computers, fridge, etc.
At home during the winter we use one small panel radiator and it is surprising how effective that is - bearing in mind our van is quite small (4 berth) - 5.82 metres length.
malheg
175
72
Coppull (Chorley)
Campervan (Alphard)
12 yrs
Whe use a small fan heater which we have found distributes the heat better and quicker than a static heater. We can switch between 1 & 2KW. Our van is 6.7m long and we find the 1KW setting is ample. You can purchace these for around £20
Also the 1KW setting is OK for sites with only 6amp. As 6A x 220v = 1320w.
Remember if on 6A only to have the heater on.
We have limited our Kettle and Toaster to 850W so we do not overload the trip if on a site with only 6A,.
Malc.
Stephen & Jeannie
4,174
3,265
Gobowen near Oswestry !!
Sold and bought a Caravan
9 years !!!!
Durr !!!!!!
We're using an 1800 watt Delonghi heater[HI] very kindly donated by Salopian on the Marjal meet. [/HI]We're using it on half power; it is more than adequate for temperatures around 5-6 degrees which we have had some nights and mornings since being out in Spain. We haven't tripped any electric supplies with it including a 6 amp ACSI site and run it in conjunction with computers, fridge, etc.
Since then I've been feckin freezing to death !!:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Fan heaters are good for a boost, but the air soon cools. Halogens are good for keeping the heat once warm and use lower power. Quartz give far better heat for less power consumption that halogens, but the bulbs do not last too long.
Use your gas heater or a 1000w fan heater to warm the place up, and keep it there with a halogen or radiator would be my advice.
11,932
9,085
I use a fan heater while on hook up 2,000w but only ever have it on 1,000 :thumb:I bought a small PIFCO but the temps between on and off were far too great :Sad: so bought a Lidl one that is digital and has a remote control-under £20 and turns on and off with only a couple of degrees between off and on :thumb:simply set it to 23/24 and it turns on and off when required :thumb:It may be a Delongi (cannot remember) but it is impresive on how it keeps close to the temp set :thumb:none of the boil then freeze waiting for the thermosat to kick in like on the Pifco.
terry
Janine
14,351
43,173
A little bit left of Middle England
2006 A/S Nuevo
since 1988
We've got a lidl one, too.
It is a convection and fan heater (although we've found that it blows cold air if the thermostat has cut in!)
It has a choice of 1000 or 200kw and a remote control.
We also take a small oil-filled radiator to leave on at night.
Romatone
46
23
Sible Hedingham
Hymer A class
Since July 2012
Hi Jamwitt . To calculate amps , divide total wattage by 240 .....2000 watts divided by 240 = 8.33 amps,. That's the way I've been told ...hope it's correct
Have a nice trip
Tony:ROFLMAO:
C
Chockswahay
I remember from my school days being taught the 'energy pyramid' in physics. I can't draw a triangle here but the basic text follows:
W
A x V
W = Watts, A = Amps, V = Volts
Just cover the one you want with your finger and apply the maths on what's left.....you only need to know 2 out of the 3 values
i.e to check total amps on a 1000 watt heater on a 240 volt supply...........would come out as
A = W/V = 1000/4 = 4 (approx)
Dunno if this helps (makes sense in my little mind :Blush:)
43,331
49,469
Have a nice trip
Tony:ROFLMAO:
the calculation method is correct but the variables are wrong.
UK benchmark for mains voltage is now 230v...not 240v...so 8.7amps is correct
2,336
10,114
Word of advice.. Insurance..
Non OEM space heating of any kind is not generally covered by your vehicle insurance..
use by all means, but never leave unattended.. bear this in mind when choosing and using ..
Feb 27, 2011
14,741
76,034
Strictly speaking the spec is 230V +/- 6% (I think) We didn't actually change our whole generation and distribution system so we are still at 240V. It is a paper work thingy to keep the brussels mob happy:Angry:.
However using 230v in this context for calculations is safer as it gives a higher current than dividing by 240v. Supply voltage on my current hookup is showing 242v which is within the 230v +6% range.
Jamwitt
Jamwitt
630
367
Chandlersford
4yrs
Thanks jim did not give that a thought :thumb:
gozomike
Funster Life Member
1,001
863
Warwickshire - sometimes - but not often
Wildax Constellation
Since August 2008
For those into the calculations don’t forget it’s the rated voltage that maters and that is rarely quoted. For instance a 1,000 watt heater element rated for and run on 240 volts would draw 4.166 amps. If the voltage was dropped to 230volts it would draw 3.993 amps and give 918.4 watts. The resistance of the element (57.6 ohms in this example) remains the same. The reverse would also be true, the higher the voltage the higher the current and power output, until it goes bang . Also the motor current needs adding.:RollEyes:
For the original question and those working on the KISS principal, I run a fan heater normally on 1kw but with the option of 2kw if it is very cold and the site power is up to it.
I quite fancy one of these though http://www.argos.co.uk/static/Product/partNumber/4111012.htm but not the price.:ROFLMAO:
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
For those into the calculations don’t forget it’s the rated voltage that maters and that is rarely quoted. For instance a 1,000 watt heater element rated for and run on 240 volts would draw 4.166 amps. If the voltage was dropped to 230volts it would draw 3.993 amps and give 918.4 watts. The resistance of the element (57.6 ohms in this example) remains the same. The reverse would also be true, the higher the voltage the higher the current and power output, until it goes bang /QUOTE]
Sorry that's incorrect. The voltage and current are inversely proportional. Ohms law. So, if the voltage drops the current increases and visa versa for a fixed load. Consequently, the current drawn by a 1kW element, at 230V, would be higher than at 240V and in fact would be 4.35A.
gozomike
Funster Life Member
1,001
863
Since August 2008
[HI]Sorry that's incorrect. The voltage and current are inversely proportional.[/HI] Ohms law. So, if the voltage drops the current increases and visa versa for a fixed load. Consequently, the current drawn by a 1kW element, at 230V, would be higher than at 240V and in fact would be 4.35A.
You are assuming a fixed wattage. The figures I am quoting are for a unit where the voltage is varied.
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
Electric heaters
I would agree with most and suggest a fan assisted heater the best option. Something with selectable output settings, so you can adjust it to the size of supply and thermostatically controlled. For your size of van I would reckon a 1.5kW heater would be suffice to get you up to a comfortable temperature in a reasonable amount of time without any other heat source.
Infra red heaters, quartz/silicon, don't warm the space (air) directly, they warm objects in the space and, thus, give the impression of fast operation. An uncomfortable side effect, in a small area like a motorhome, with infra red heating your eyes can feel very dry.
Oil filled radiators, and the like, take much longer to distribute their output but may be useful to maintain a temperature level once it's been achieved by another source.
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
Sorry, still not quite with that. Do you mean where an appliance is designed to operate on dual voltages, say 110/230V, and is switchable between the two?
I would agree, with that sort of arrangement the wattage may be changed due to the switching operation ie change in voltage rating.
gozomike
Funster Life Member
1,001
863
Since August 2008
Not quite. Taking a more obvious item such as a car bulb, if you turn the lights on and then start the car the lights will dim due to the reduced voltage whilst the starter is running. The bulb may be rated at say 60 watts with 12 volts but with the volts dropping then the wattage output will drop as will the current it is taking.
What you are thinking about is where the 60 watt bulb is on 12 volts it will take 5 amps, a 60 watt bulb designed and running on 240 volts would only take 0.25 of an amp.
The heater is designed for a fixed voltage say 240 volts to give its full output. If you moved to a lower voltage area, say going from the UK with 240 volts to Europe with a 230 volt supply, the wattage output would be lower as would the current drawn. You need to take the resistance of the element into account, as this would be fixed for the unit, by using ohms law.
It can get confusing but I hope this helps.
Mike in Gozo
1Oll
175
86
Cheshire
A Class (German B Class!)
6+ years
Greenhouse heater.
I have a greenhouse fan heater on over the winter, set on lowest setting and Froststat.
I also keep it in the Amethyst all the time when travelling just in case we are ever on EHU. ( never this year). Bought it from a car boot sale, it was on a charity stall and was brand new.
I leave all cupboards and loo door open. Everything stays dry and no mould or condensation.
Some years ago when I had a caravan with no winter heating all the melamine surfaces were covered in green mould after being left for a couple of months
Brian in Sunny Macclesfield.
oldun
747
162
St Neots
VW Campervan
Since 2001
Malc.
True but can be drafty and they are much noiser - i find that they disturb my sleep when switching on/off.
