I've had my ecu remapped to delete the egr function... its still in place but permanently shut and disconnected...Techno help please, I have disconnected egr on 2.5 Renault after continuous limp mode, now runs as normal. Anyone in Leeds area do re mapping or is their any other way of fooling ecu
Yes.But is the cat empty?
Someone who has your van will be more help but as a guide...if you have an electronically activated egr valve as opposed to a mechanical then you may have issues if you just blank it off... they have feedback to the ecu and that can generate fault codes...Just finished reading this whole thread , and wow...
Anyway I've now decided to add the task of blanking off the erg valve.
Ours is a 2007 Fiat 2.3 Ltr 130 Multi jet which has about 15k on the clock.
Once I install the blank of plate do I need to do anything else ? Like with the ecu ?
This is the correct part isn't it?
Also can anyone rec a cheap decent reader to read / reset any engine codes
Fiat Ducati 2.3 multijet reg 2010. 29,000 miles.
Eleven months ago (October 2016), I suffered major engine failure due to the auxiliary belt shredding and wrapping itself around the timing belt.
The engine has been rebuilt and the van returned to the repairer some 100 miles from me three times now and I have finally lost all faith in this garage.
The engine appears to run fine and I have no fault codes. After 1200 miles touring around France I estimate that I have consumed 12 Ltr of coolant. White/grey smoke could be seen exiting the exhaust after idling at the Toll gates and on occasion under load, black smoke. There is no evidence of emulsified oil in the engine.
Reading all the above I have a feeling it may be my EGR cooler/valve that is causing the problem? What do you guys think? Taking the van back to the repairer is not an option.
Cheers adgy
Almost definitely the coolant is getting into the engine. If the rebuild involved a head skim, I would be worried that the head is scrap.Fiat Ducati 2.3 multijet reg 2010. 29,000 miles.
Cheers adgy
Cheers adgy
@Irishrover I’d say yes, but without seeing the vehicle I can’t say for sure. EGR systems for Diesel engined passenger vehicles, vans etc have been in production pre 1990’s. I had a 1991 2.0 diesel Montego estate fitted with the Prima Perkins Di engine, this had a vacuum egr system. Took me ten minutes to make and fit the banking plate. Sadly the body fell of the engine after 200k miles. I sold the engine & gearbox to a guy who fitted to a Maestro van. Excellent engine. Crap car producer.Just found and read this thread from start to finish...great stuff!
I too would blank off the EGR but not sure if my van has one? its a 1999 2.8 Fiat Ducato idtd....any techies on here know if that engine has an egr?....
Mine is a 2005 version that doesn't have one.@Irishrover I’d say yes, but without seeing the vehicle I can’t say for sure. EGR systems for Diesel engined passenger vehicles, vans etc have been in production pre 1990’s. I had a 1991 2.0 diesel Montego estate fitted with the Prima Perkins Di engine, this had a vacuum egr system. Took me ten minutes to make and fit the banking plate. Sadly the body fell of the engine after 200k miles. I sold the engine & gearbox to a guy who fitted to a Maestro van. Excellent engine. Crap car producer.
Ignore A/C pressure sensor code, its probably just needing some gas.
However, Throttle control valve and EGR, codes are a bit of a worry.
Having read the thread (not all of it) It would appear that at the very least a Physical clean may be required. Before I go down the road of ripping lumps of Engine off, on the driveway in the cold. Has anyone ever achieved success with "Engine Cleaners" i.e. Wynns etc?. Even if it just gets me into the new year and milder weather.
The RAC guy, deleted the codes, and E-Mailed me the printout, The EMC light is back on again, so it looks like it is not a "one off".
