Black tank versus cassette (6 Viewers)
Feb 24, 2013
13,083
101,459
Bolsover, Derbyshire
Hymer S800
not long enough
we had caravanned for years, progressing from porta potties to cassettes, now have a Hymer with black tank approx. volume 120 litres
result we, (I) thought, far less emptying, although in fairness Bev does her share (both filling and emptying!!)
However, emptying a black tank is not always a given
We have found many sites with only a standard elsan type raised ceramic hole in the ground, not much use when you depend on gravity from an outlet only 6" off the floor!!
So, having purchased a builders bucket, and used it a few times to decant a few litres to turn off the red light, carrying it open topped and smelling to the elsan point to avoid moving, or where there was no option to dump, walking in fear of the handle giving way on a CC site roadway:Eeek: what would the wardens make of that:Eeek:
I now own a cassette, to empty my black tank into to move in a more controlled fashion to the elsan point
Progress.................... ??
Better spec................ ??
Who knows
Nov 18, 2011
11,862
43,046
Planet Earth
A van
Over 25 year's
find the sewer on the road on the site if not get your self a masecater and a smale pump best
regard lez dawson :ROFLMAO:
19,365
30,302
Hi David
You nearly have a proper motorhome now:ROFLMAO:
43,331
49,480
i would have the tank converted to a 3" valterra outlet and use a macerator.
Pump up to around 100ft and to a height of around 10ft through a 5/8th garden hose.
DavidG58
Feb 24, 2013
13,083
101,459
Hymer S800
not long enough
At last a proper answer, but I am none the wiser yet
We have a macerator on the inlet to the tank, how easy is it to fit (have fitted) these outlet mods?
TERRY what do you reckon :thumb:
19,365
30,302
43,331
49,480
you must have small bore pipework between pan and tank to need a macerator on the inlet.
I guess a it depends on the tank orientation as the 3"outlet is a little bulky to say the least.....but there will be a way.
With a bit more work you could connect the grey tank via 1 3/4" sink waste pipe to the same outlet.
The tank would need a suitable hole cutting to take the 3" pipework, a blade valve is then fitted in an accessible place then the macerator connects to the outlet.
Open the blade valve and turn on the macerator....making certain all connections are sound, black waste under pressure goes a long way if it leaks.
See Robin Williams in the film 'RV'
It would also allow gravity dumping over a manhole via a 3" hose.
I have a 20ft hose for remote manholes and a 3ft hose for drive over manholes.
I dont recall ever having to use the 20ft one.
Link to an example slide valve....they are cheaper (postage) in the uk
DavidG58
Feb 24, 2013
13,083
101,459
Hymer S800
not long enough
Many thanks, I am increasingly convinced my MH was a total prototype, we have a toilet that I thought for 6 months was a 'bog' :ROFLMAO: standard ceramic toilet, it is actually plastic, but 'stuff' goes out the back through approx. 2" horizontal outlet hole, through a macerator which looks more like 3" back into a 1.5" pipe down to black tank
I think my back up cassette option will have to do for now :thumb:
43,331
49,480
that sounds very much like a marine toilet.
Agreed, the cassette is by far the cheapest option
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
That is a toilet cassette with a springloaded trap for filling probably too tall to go under your van.
A Tote is made to go under caravans etc and has a screw top entry point.
I was thinking something more like this
might be something better out there of course.
DavidG58
Feb 24, 2013
13,083
101,459
Hymer S800
not long enough
I was going to buy one of those, having given 2 away when I sold caravan:Doh:
Decided I could not cope with knowitalls telling me I was emptying grey water in wrong place, when dumping toilet waste in elsans!!
On a much nicer subject just seen photos of your place, brace yourself we are coming soon :thumb:::bigsmile:
11,932
9,090
I think you should give me that van and buy yourself another :thumb: after all it's full of shit :winky:
I would go to a garden center/fish pond place and buy some hose that fits your outlet and simply make a connection so that you can screw it onto your outlet ---On my van the grey is emptied via a quarter turn 3/4 ins ball valve that I simply made a 8 ft ish long bit of hose so that I can extend by screwing it onto the valve --Nothing to stop you doing the same with the black tank obviously you need bigger than 3/4 ins,but it is a easy job once you have the correct parts --You have enough room in the garage to store a very very long extension pipe -Should have mentioned it/ made clear at the fix it meet :winky:
You need something like this http://www.screwfix.com/p/full-bore-lever-ball-valve-22mm/30584 but bigger bore to suit your outlet and some pipe /hose type to extend it
Because mine is 3/4 I simply got about 3 ins of copper pipe fitted the outlet end and shoved it into a 3/4 ins hose - now it's a case of simply screwing it onto the valve and this gives me enough length to go from my outlet at the back to the side when needed :thumb:-You need similar only bigger bore
terry
edit forgot to say you could also get another valve to fit your grey that way you can empty the black and then move it onto the grey to flush your pipe
11,932
9,090
Hi David been thinking about this and you already have valves fitted so it's really a case of extending your dump pipes --Measure the external dia of pipe and look at garden cent/fish pond or ebay for a flexible pipe with internal dia of your external dia then it's just a case of pushing the pipe on :thumb:--You must be able to go a few weeks before having to up sticks and go and dump :winky::Smile:
terry
DavidG58
Feb 24, 2013
13,083
101,459
Hymer S800
not long enough
terry
Thanks Terry
Problem is when the dump point is too high for the gravity outlet, I already have 4m hose in a side locker, just need it to go uphill!! some small sites especially don't have ground level dumps, worst ones are the standard elsan points
Black tank is not that big, we get red light on after three nights, I think 100 litres or so
:thumb:
11,932
9,090
Thanks Terry
:thumb:
Hi David I think your tanks well above any elsan point /gravity will force it up and over the emptying edge it's only what's left in the lower part of the pipe,pull it off and hold it high :Eeek:::bigsmile:
Only 3 nights :Eeek: you probably have the best solution now then :thumb:
terry
Mousy
3,485
20,319
Sa15 2DG
Hymer S840 Merc auto
Go on David, just change your van...you know you want too:roflmto:
Sep 3, 2013
768
816
Crowthorne, Berkshire
1992 RMB Silver Star 670
One year. A whole one!
David,
I think (if not already mentioned before) you need this....
And a set of crocodile clips to connect to your leisure battery and some hose for the discharge and some more (with the correct reducer / enlarger adaptor) for connecting to your MH.
That'll easily shift your load uphill. I think the head is around 3 metres.
You can buy RV macerator pump sets. That's what I bought for Udo, but admittedly with the 3" connection that Udo has. I'm sure you could find a pump kit that works for your Hymer.
DavidG58
Feb 24, 2013
13,083
101,459
Hymer S800
not long enough
David,
Now that looks like an option, just have to hope the pipe does not jump up when pump starts, I reckon it could send it a few feet:Eeek:
Many thanks for that link, we have a 12V socket in the garage where the dump valve is already
David
Mousy
3,485
20,319
Sa15 2DG
Happy bowl liners. Won't help with your emptying issues but further to my demo at Chester, soaringman bought some and said it had "transformed their motor homing experience".
Go on David, resistance is futile. Still the best thing in my van!
2657
Can't see why you would need to alter the outlet on your black tank in order to use a macerator. The inlet on my macerator is around 2in dia and I had to use an adaptor from the 3in outlet on the 5'er to use it.The outlet is smaller and the only place I could find the right diameter was from a garden pond supplier.
I normally use a system similar to yours but using an old aquaroll as my outlet is high enough to use this via the same pipe adaptor.
I no longer use the macerator and would sell it cheaply, little used, but it is with the 5'er in Portugal and I will not be returning there until November.
http://www.jabscoshop.com/marine/marine-toilets/toilet-waste-pumps/18590-2092-macerator-pump.htm
DavidG58
Feb 24, 2013
13,083
101,459
Hymer S800
not long enough
As those that have met me so far know and will testify I don't do technical, in fact I barely do.
The macerator pump idea sounds good, but I am most likely to stick with a wheeled cassette when needed to empty some black waste when needed
David
2657
David
I would agree, if it works for you why go to the bother and expense of using a macerator.
We only got ours as we intended leaving the 5'er permanently on a site near Portimao that had a form of waste disposal via a manhole but thing's didn't work out.
The 5'er is now permanently sited near Tavira and I now use the aquaroll for emptying but try and use the site facilities mainly.
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
120 litre black tank? I'd say only stay on sites in Germany with a drive over grid built for German motorhomes with a black waste tank.
That way you'll have the ideal set-up :RollEyes:
