12v hair driers (1 Viewer)
Oct 7, 2013
5,898
36,949
South Wales
Swift Escape Compact
Since 1988
Has anyone found one that actually does the job?
Need one for when on Aires etc. not for me, I don't have that much, but for Mrs Maison.
Oct 15, 2012
10,197
57,516
Market Harborough
C Class Laika Ecovip 7R
Have heard there not worth the money, very little power, some on here advise getting gas powered hair straighteners. (y)
Jan 27, 2014
2,076
4,502
mid wales
carthago chic i51.
I have one its ok its better than nothiing but
a gas tongs with a spare gas cartridge
Is as davidbadham says the answer
I have one and it is good hope this helps .
maison
Oct 7, 2013
5,898
36,949
South Wales
Since 1988
I don't bother with a hairdryer. I let my hair dry naturally then use my straighteners to tame the tangle!
Do you use gas powered hair straightener ?
If so, what model?
can you tell us the model you use?
Jan 27, 2014
2,076
4,502
mid wales
carthago chic i51.
Baby bliss from boots compact mind this some time ago. but can still get refill cartridges from there good luck .
big map
4,597
182,269
Poole
I'm sure that if someone could make a great one it would be a best seller.
M
Madwife
12v hairdryer I found that it is quicker to let your hair dry naturally than use it.
Kath
2,337
10,147
it would need to be at least 500 watt to do the job..
at 12vdc that pulls ~ 42 amps.. the flex would be as thick as welding cable .. or battery jump leads with same size croc clips.. :eek:
Jan 22, 2013
1,254
60,428
London SE
A class Adria vision I707
since 1971
Shut all your vents on the hot air blower except one, then fit a convoluted hose to the open one and turn up the heat to max,
Shouldn't take lone to dry the missus hair
big map
4,597
182,269
Poole
So are you saying it will never be made? I bet if a bloke wanted / needed this item of desire a way could be found to produce :)
2,337
10,147
If you reduce the wattage to an acceptable current, say 4 amps .. that only gives you 48watt .. just doesn't cut it ..
use a gas heat exchanger and a 12v blower could do the job .. but would be expensive to develop and market.. customer base big enough ?
sorry.. not investing.. I'm out :LOL:
hah ha .. someone has patented it already
US Patent #6959707
gas combustion hair drier
GJH
29,450
38,827
None, now sold
2006 to 2022
Jill has BaByliss Pro Cordless Hair Tongs in two sizes and a Braun (I think) straightener, all gas powered. I only know because she just bought the larger tongs to replace the 15 year old Braun equivalent which went wrong last weekend.
maison
Oct 7, 2013
5,898
36,949
South Wales
Since 1988
That explains it then!
Perhaps one crocodile clip on each pinkie finger, connect to battery via jump leads, and immediate curly hair.
Ah, but it's hair straightening she is after. Never mind.:whistle:
big map
4,597
182,269
Poole
US Patent #6959707
:bear:
CWH
5,151
247,514
WildAx PVC
From November 2013
  • Lifeventure softfibre trek towel.
  • Brush or comb.
  • Then let your hair "go freelance" as Him Indoors calls mine.
They'll dry anything, they come in various sizes. I have giant in the moho (for showering), medium in my rucksack (for rainy hikes), small in my daysack (for whatever)...
(They do other types of fibre, not as good IMO, and definitely NOT the microfibre.)
http://www.cotswoldoutdoor.com/?fus...source.y=0&searchvalue=lifeventure+trek+towel
https://www.lifeventure.co.uk/product/washgear/softfibre-trek-towel
Moodybrook
802
651
Wet and cold place outside of M25
4 wheels and a pointy end
still in nappies
wants to be at 80 quid .. :eek:
Got mine on fleabay £35 posted, A REAL BARGAIN ! We have only used it a couple of times last year Jim. It's potential was appreciated. Ran off the Solar panel, nae bother !
It was bought with a view that without it, or air con, touring central europe/northern Italy would be a no no ! Neither of us enjoy being cooked alive, bitter experience in Poland of all places 40+ for a fortnight in a non air conned car, and the Mrs's outlaws didn't have air con either.
Sep 3, 2012
7,556
26,081
Cheshire
C Class Elddis 175
8+ years
US Patent #6959707
I've got one in my garage at home if you want it -it was last used for stripping paint off doors some years ago -not sure if it uses parafin or petrol now-but its made of brass and shines up a real treat.:ROFLMAO::ROFLMAO::ROFLMAO:
