12v hair driers
Discussion in 'Motorhome Chat' started by maison, Feb 28, 2015.
  1. maison
    maison Funster
    Oct 7, 2013
    1,849
    4,492
    South Wales & Burgundy
    Has anyone found one that actually does the job?
    Need one for when on Aires etc. not for me, I don't have that much, but for Mrs Maison.
    • Like it Like it x 1
  2. Allan & Loren
    Allan & Loren Funster
    Dec 8, 2014
    1,297
    1,921
    Leyland, Lancashire
    I don't bother with a hairdryer. I let my hair dry naturally then use my straighteners to tame the tangle!
  3. davidbaldam
    davidbaldam Funster
    Oct 15, 2012
    3,189
    8,262
    Market Harborough
    Have heard there not worth the money, very little power, some on here advise getting gas powered hair straighteners. (y)
  4. Moodybrook
    Moodybrook Funster
    Jul 7, 2013
    800
    651
    Wet and cold place outside of M25
    I use a towel very carefully on both of them (hairs) :whistle:
    • Like it Like it x 3
  5. Beacons
    Beacons Funster
    Jan 27, 2014
    1,043
    876
    mid wales
    I have one its ok its better than nothiing but
    a gas tongs with a spare gas cartridge
    Is as davidbadham says the answer
    I have one and it is good hope this helps .
    • Like it Like it x 2
  6. maison
    maison Funster
    Oct 7, 2013
    1,849
    4,492
    Do you use gas powered hair straightener ?
    If so, what model?
    can you tell us the model you use?
  7. Beacons
    Beacons Funster
    Jan 27, 2014
    1,043
    876
    mid wales
    Baby bliss from boots compact mind this some time ago. but can still get refill cartridges from there good luck .
  8. maison
    maison Funster
    Oct 7, 2013
    1,849
    4,492
    :calig:
  9. big map
    big map Funster Life Member
    Mar 8, 2009
    2,501
    19,101
    Poole
    I'm sure that if someone could make a great one it would be a best seller.
  10. Madwife
    Madwife Deleted User
    12v hairdryer I found that it is quicker to let your hair dry naturally than use it.
    Kath
  11. scotjimland
    Jul 25, 2007
    28,975
    25,674
    it would need to be at least 500 watt to do the job..
    at 12vdc that pulls ~ 42 amps.. the flex would be as thick as welding cable .. or battery jump leads with same size croc clips.. :eek:
  12. ivorantony
    ivorantony Funster
    Jan 22, 2013
    518
    551
    London SE
    Shut all your vents on the hot air blower except one, then fit a convoluted hose to the open one and turn up the heat to max,
    Shouldn't take lone to dry the missus hair
  13. big map
    Mar 8, 2009
    2,501
    19,101
    Poole
    So are you saying it will never be made? I bet if a bloke wanted / needed this item of desire a way could be found to produce :)
  14. scotjimland
    Jul 25, 2007
    28,975
    25,674
    If you reduce the wattage to an acceptable current, say 4 amps .. that only gives you 48watt .. just doesn't cut it ..
    use a gas heat exchanger and a 12v blower could do the job .. but would be expensive to develop and market.. customer base big enough ?
    sorry.. not investing.. I'm out :LOL:
    hah ha .. someone has patented it already
    US Patent #6959707
    gas combustion hair drier
    [​IMG]
  15. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,949
    Jill has BaByliss Pro Cordless Hair Tongs in two sizes and a Braun (I think) straightener, all gas powered. I only know because she just bought the larger tongs to replace the 15 year old Braun equivalent which went wrong last weekend.
  16. maison
    maison Funster
    Oct 7, 2013
    1,849
    4,492
    That explains it then!
    Perhaps one crocodile clip on each pinkie finger, connect to battery via jump leads, and immediate curly hair.
    Ah, but it's hair straightening she is after. Never mind.:whistle:
  17. big map
    Mar 8, 2009
    2,501
    19,101
    Poole
    :bear:
  18. scotjimland
    Jul 25, 2007
    28,975
    25,674
    .. that must have broke you're heart :LOL:
  19. scotjimland
    Jul 25, 2007
    28,975
    25,674
    buy one of these ..
    no more barber bills, no more expensive shampoos no more drying hair .. no lice or nits :LOL:
    [​IMG]
    • Like it Like it x 4
  20. CWH
    CWH Funster Life Member
    Jan 29, 2014
    3,204
    14,091
    under a wand'rin' star
    • Lifeventure softfibre trek towel.
    • Brush or comb.
    • Then let your hair "go freelance" as Him Indoors calls mine.
    They'll dry anything, they come in various sizes. I have giant in the moho (for showering), medium in my rucksack (for rainy hikes), small in my daysack (for whatever)...
    (They do other types of fibre, not as good IMO, and definitely NOT the microfibre.)
    http://www.cotswoldoutdoor.com/?fus...source.y=0&searchvalue=lifeventure+trek+towel
    https://www.lifeventure.co.uk/product/washgear/softfibre-trek-towel
