SOLD Witter ZX502 towbar mounted foldable 2-cycle carrier (1 Viewer)
PandS
9
4
Woking, Surrey
Coach built
Since 2009
For sale - Witter ZX502 towbar mounted foldable 2-cycle carrier - used during summer 2018 - excellent condition.
Number of bikes – 2
Suitable for eBikes – No
Maximum Weight per Bike – 20kg
Maximum Load Capacity – 40kg
Unladen Weight – 17.8kg
Foldable – Yes
Extension from Vehicle – 575mm folded
Tiltable for Easy Boot Access – Yes
Mounting Type - Towbar Mounted
Electric Socket - 7 & 13 pin plug
Lockable – Yes, carrier to vehicle and cycles to carrier
The carrier clamps to a UK towball using a unique clamp down action.
Additional Information
ROLL-IT - Portable, the carrier can be easily moved around on built in wheels when not in use or when manoeuvring into position.
LOAD-IT - The carrier loads vertically onto the towball; this reduces back strain and makes the attachment incredibly simple with minimum effort.
CLAMP-IT - Using a unique clamp down action it fastens to the towball with the same force automatically every time it is lowered into position.
TILT-IT - The platform will tilt rearwards when in use to facilitate boot access with or without the cycles loaded.
USE-IT – Simple and easy to use, minimum effort to install, designed specifically for one person attachment without continuous adjustments.
FOLD-IT - The platforml folds up to reduce rearward clearance when not in use.
FLIP-IT - The lighting board can then be flipped down to display rearward.
DRIVE-IT - The vehicle can be driven with the carrier attached in the fold up position and can be locked to the towball. Increased security is ensured by support arms that will lock your bikes to to the carrier.
Price £175 or reasonable offer. Collection from Woking, Surrey
Selling due to change of motorhome.
Minxy
31,964
63,597
E Yorks
Carthago Compactline
Unless I'm going ga-ga (don't answer that!) I can't see a price ...
P
PandS
9
4
Woking, Surrey
Coach built
Since 2009
Apologies - £199 ono. Advert amended. Thanks for pointing that out. Regards PM
