wotme
If I can't fix my existing rear view camera I'm thinking of installing a wireless system are they any good?
Can't guarantee the connector plugs are the same across different suppliers - DRW Electronics chatted with me about this.This is my existing monitor which I think has failed, it looks similar if not identical to currant models but I have no makers name to go by. Do you think the connections would be the same if I bought a similar model, If there was an outlet near me which there isn't I could have it tested. The reason I think its failed is I'm not getting anything on the screen ie its not going blue and saying no signal.
There might be no power at the monitor. Take it off, connect to a good (ie working) 12v source then try. Don't forget to switch it on.This is my existing monitor which I think has failed, it looks similar if not identical to currant models but I have no makers name to go by. Do you think the connections would be the same if I bought a similar model, If there was an outlet near me which there isn't I could have it tested. The reason I think its failed is I'm not getting anything on the screen ie its not going blue and saying no signal.
