Winter fridge vent cover (1 Viewer)
Aug 19, 2013
2,759
3,771
Wells, Somerset
Elddis 115
since 2004
Can't I just stick some Duct tape over the vent as a temporary measure? I read that the winter covers you buy from Dometic allow you to use the fridge on gas while their vents are still fitted. Does this mean that they have reduced vent holes, or do they seal the vent completely?
DBK
17,912
47,662
Plympton, Devon
PVC, Murvi Morocco
Mine block the top vent completely except for the outlet on the right from the burner. The bottom vent has a slot about 15mm wide at the bottom, the rest is blocked off.
But I wouldn't take the chance. If you don't want to buy proper screens just run it without them. :)
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
I can't use the top cover or my freezer doesn't work.
Duct tape will do the job if you leave alittle gap on each. But I wouldn't fancy trying to clean the glue off in the spring though.
OCD
Mar 18, 2022
216
238
Dublin, Ireland
Looking
Folks a bit of a thread bump ...the photo shows fridge vents what the craic when I'm hosing the big girl down for a wash ..I assume water getting in here is a no no.
Jan 28, 2008
9,946
17,643
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
the small area on the right of the top vent is the flue so dont cover that instead of duct tape on the out side i would wedge cardboarad or similar in side if you need to ive never use covers in 15 years
Reactions: OCD
Sep 3, 2012
7,054
23,303
Cheshire
C Class Elddis 175
8+ years
Don't know what you mean re the "Is100 version" but the vents are louvered such that water coming down ,from above the vents ,shouldn't enter the vent ,unless the wind is blowing hard or you are spraying your van with water horizontally at the vents.
Jan 28, 2008
9,946
17,643
Renalt burstner
i did have a bottom cover for those if i find it you can bhave it
  • Thanks
Reactions: OCD
OCD
Mar 18, 2022
216
238
Dublin, Ireland
Looking
Ls 100 is the part number of the vents .
7,054
23,303
Cheshire
C Class Elddis 175
8+ years
Never had winter covers on ours,they are unused in a bag in the garage. I was my van with an extendable brush and a bucket ,never used a hose or spray type washer on any van I have had.
High pressure sprays can lift decals and get under vents , roof lights, locker door seals etc not worth the risk for the sake of a few extra mins washing from a bucket (y)
OCD
Mar 18, 2022
216
238
Dublin, Ireland
Looking
Are the covers u have for the vents in my photo?
Apr 22, 2018
6,537
12,040
Herts.
Adria Coral lowline
You don’t have covers fitted in your photo.
I use my covers when parked up as I don’t have the mesh on the inside of them, but don’t worry about refitting them when washing, I just don’t direct water towards the grills. They can deal with a bit of water ok.
Reactions: OCD
OCD
Mar 18, 2022
216
238
Dublin, Ireland
Looking
In the photo it doesn't have the "winter" covers on ..I don't get this yoke until 14 April..just can't remember seeing a pair of them when we were viewing it .
kevenh
3,320
11,797
Thatcham
Compass C-Class
I'm a Progressing Newbie
Those never running fridges with a winter cover over the lower vent, are you on gas or lekky?
Is the outside temperature lower than 8deg C?
On gas, after a couple of trips with the outside weather mild, we couldn’t understand why our fridge was rubbish at getting cold on a later more wintery trip.
After a bit of RTFM, we saw Dometic say fit a winter cover over the lower vent if the outside temperature lower than 8deg C.
Doing that suggestion regained normal fridge cooling within a short time span. 👍🏻😎
Reactions: OCD
OCD
Mar 18, 2022
216
238
Dublin, Ireland
Looking
Don't get the keys until the 14th of April.
Jan 8, 2013
8,395
11,383
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
If you take a fridge vent cover of you will see that there is nothing waterproof inside there. In fact its all usually bare wood as well
Reactions: OCD
Feb 19, 2020
1,272
1,392
North Ayrshire
Adria Matrix 670SC
Newbie
Thetforde covers fit in between the louvred vent and the frame. There is a cut out to allow some air in. The idea is to cut down on the cold air and make the fridge more efficient.
Reactions: OCD
