windscreen wipers stooped working
octopush
portsmouth
coachbuilt
2days
Hi all not been on here for a long time. i have a problem with my Peugeot boxer Starblazer 2004. I had a problem with the earth wire from the battery to the chassis witch made all the lights flicker and the van not start i sorted the earth out by putting a new cable on but since then the windscreen wipers and windscreen washers do not work I have looked at the fuses and relays but can not find anything wrong with them it is a bit vague to as witch ones they are also looked at the wires on the stalk and all seem well there. Any help or suggestions would be appreciated.
The earth strap on the 2004 Ducato ran from the gearbox to the chassis leg.
Have you checked for rodent damage to your wiring ?
only way is to work back with a meter start at the motor and see if theres power there then the switch probably need to find a wiring diagram
No signs of rodent damage.
There is no power at the motor or switch.
Google Peugeot fuse box.
On my 57 plate it’s.
Second row from left 3rd one up from bottom is the wiper fuse
I think the 2004 fuse box is the same....
EDIT....seamingly not.
but none appear to be listed as wiper motor
Try fuse 8 in the engine compartment
Can not find a relay for the wipers think it is built into the motor
Thank you i will have a closed look at fuse 8 as it seems to do both washer and wipers.
I will let you know how i get on when im home from work.
[/QUOTE]
No luck with fuse 8 swapped it for another one so nothing wrong with the fuse tested for power at the point the fuse goes in and there is power there. do not know were to go next anyone got an idea
“there is no power at the motor or switch”.
So surely it must be the fuse,worth checking again? Maybe it’s a different fuse.
Maybe one of the Funsters who know all about leccie will be along soon to help!
Agreed..... The legend may say fuse 8 but it doesn't mean it actually is.
Use a multimeter set to Ohms, remove each fuse in turn and test for continuity.
A visual check often isn't enough
Bloody hell ppj, So, I must have learnt summink from being on here for three years! :LOL:;)
I will go throw all the fuses tomorrow night
Well I checked all the fuses even some that were hidden and they are all good. Looks like I’m going to have to take it to an auto electrician
Anyone know were I can find the BCM on my 2004 Peugeot boxer
They also have individual earth wires going back to various earthing points under the bonnet on both sides if the same as the Fiat?
