Window black out and fly screen not rolling up any more
Van Conversion
since 2017
Hi I’ve had No problem with these before but now not rolling up and down. Ive seen a you tube vid showing ways to repair them just wondered if anyone has a clear method for this
Thanks in advance
Thanks in advance
What make/sort of screen. Suggest photos? I've had problems and sorted them but depends on what your prob. is.
Hi There isn’t a make on the screens but in the photos the fly net half springs up and down perfectly but the blackout section won’t re coil down.
Looks the same as mine, and mine has stuck also. Have not yet had an opportunity to have a good look at it, so would also be interested in any Funsters solutions.
Sorry but not the same problem, different type of blind than mine. In my case one string that guided the return of the blind had broken. A little spring that the string threads through had corroded and the rough rust had worn away at the string. I found that there was enough spare string to pull further though the mechanism to re tye the string at the broken end. The blind, you will find, is attached to wall with screws possibly hidden under covers at the corners or visible, as mine were. It should be an easy matter to take blind off wall, turn upside down and you can probably unscrew sides and ease blind apart to get an idea what problem is. Take it slowly so that you can put back together again.
Thanks for the reply, much appreciated
