- Mar 9, 2020
- 57
- 58
- Autotrail Imala 615
- I'm a newbie
Read a lot recently about 'Wild Camping' my question is " How long would one Leisure battery last" ? Not that we will be doing it any time soon
Yes realised it was a stupid question when I posted it. Can't see how to delete itDepends on many factors:
1. How big is your leisure battery (output)?
2. What condition is it in?
3. What time of year will it be?
4. Is it required to operate blown air heating?
5. How much energy does you lighting use?
6. Is all your lighting LED?
7. What time do you go to bed?
8. Do you intend to operate a TV / satellite box?
9. What will you be charging from your 12 volt supply - pc tablet / phone(s)?
10. Do you use an inverter?
11. What other items will operate from your 12 volt supply?
12. How long is a piece of string... ?
Not a stupid question, just needs quantifying a bit.Yes realised it was a stupid question when I posted it. Can't see how to delete it
No offence taken. My fault, didn't think the question through.Not a stupid question, just needs quantifying a bit.
People cleverer than me can provide you with detailed calculations to work out the precise (or almost) answer.
PS Sorry, I didn't mean to be rude in my previous post, just illustrating all the variables.
Get some solar panels and another battery and the answer is all summer and a good while in spring and autumn in the UK. And go further South and the answer is nearly all year.Read a lot recently about 'Wild Camping' my question is " How long would one Leisure battery last" ? Not that we will be doing it any time soon
Accurate answer is somewhere between 4 hours and 2 monthsRead a lot recently about 'Wild Camping' my question is " How long would one Leisure battery last" ? Not that we will be doing it any time soon
It depends on how much juice your battery holds, what rate you use the juice, and how you put the juice back into it.my question is " How long would one Leisure battery last"
So say the optimists. The pessimists are not so sureNot that we will be doing it any time soon
If you are checking your battery during the day the reading you will get will be the voltage that the panel and solar regulator is producing and is not a measure of the health of your battery. The battery itself will never show a reading as high as 13.5V unless it is being charged or recently been charged by a solar panel, alternator or mains charger.I have a multimeter and a portable solar panel. I keep a check on my battery and don't let it run below 13.5 if I can help it.
TOM love the term freedom camping ! So much nicer than FLT!?I've no idea about the technical aspects and the Hab battery is not easily accessible.
However, me alone Freedom Camping,
The fresh water tank for cooking and washing with a shower every few days.
14Kg? gas bottle.
Hab battery for lights, powering phones, tablet, all the minor things that need a 12v supply and a lot of DVD watching.
I don't need civilisation for three days, but I tend to make a five mile drive every morning for a coffee run and civilised toilets.
Very true, Continental vans e.g. Hymer use correct size wiring the main connections to the hab battery and split charge wiring are 16mm sq. With a flat battery you can get over 40 amp charge rate from the split charge, under normal conditions with the battery partly discharge it will start at 20 - 25 amps and once the battery voltage rises a bit it will drop to 12-15 amps.We’ve done over a month , in southern Europe, 1battery and no solar.
however we move on every 2 days, so engine charges the battery as we drive.( have picked up some British vans can’t do this....others will correct and give more detai) and we get to a site every 4 to 5 days for EHU ,and laundry.
Beware though. Those figures are for mains electricity rather than the 12v battery the OP was referring to. To convert the ampages to 12V you will need to multiply by about 10. And you will need a big battery bank and an inverter to use most of the mains appliances listed.This info may be useful, but I don’t know how accurate it, photographed it at a camp site
I think the list was assuming EHUBeware though. Those figures are for mains electricity rather than the 12v battery the OP was referring to. To convert the ampages to 12V you will need to multiply by about 10. And you will need a big battery bank and an inverter to use most of the mains appliances listed.
It was indeed. But the OP and all the other posts on this thread were assuming that there was no EHU. Hence the warning. I did not want people who had no EHU to take those amperages as gospel for their set up.I think the list was assuming EHU
Its actually a good question because without asking you'd never know all the things you have to take into consideration.Yes realised it was a stupid question when I posted it. Can't see how to delete it
