absolutely doable yesWe have a terrestrial tv aerial that is obsolete. It has pole that you push up to raise and rotate the aerial. I'd like to keep the pole/elevate/rotate functionality but substitute a 4g aerial for the tv aerial. That way, I wouldn't have to make a new hole in the roof for the cable. The cable could come down the pole like the tv aerial lead does now.
Does this sound feasible?
I did this on our previous van, I actually fitted the wifi booster to the existing TV aerial casing so I could adjust the angle as well as direction. I cut off the RJ45 plug to enable the cable to go through a smaller hole in the pole, BUT BUT BUT I was warned it was essential to rewire it exavtly the ame way or it could damage the booster.We have a terrestrial tv aerial that is obsolete. It has pole that you push up to raise and rotate the aerial. I'd like to keep the pole/elevate/rotate functionality but substitute a 4g aerial for the tv aerial. That way, I wouldn't have to make a new hole in the roof for the cable. The cable could come down the pole like the tv aerial lead does now.
As long as you sikaflex where the cable from the antenna enters the pole mount and down into the van it should be as watertight as the old TV antenna I would have thought as it's the same pole / design. The 4g antenna "should" just clamp to the side of the existing / old pole with a serrated u bolt clampHandyAndy-thanks. I wonder how easy it will be to remove the tv aerial and ensure that the directional 4g aerial is watertight?
Giff Gaff. Damned spell check.Hoff gaff are about to boost £15 8GB up to 15GB data. Unltd available for £25 but can't comment about Europe cover and they do throttle back after 25 GB.
No contract, but can choose 30fay auto renewal and change package size every month.
Use these for my phone sim and it’s really good and flexible in the uk (piggy backs on O2 network). But they are really quick to cut you off if you’re in Europe; after 8 weeks in EU they cut off our roaming every time!Hoff gaff are about to boost £15 8GB up to 15GB data. Unltd available for £25 but can't comment about Europe cover and they do throttle back after 25 GB.
If you mean mifi “dongle” then yes they are fine. You just connect to them via Wi-fi. You just need to be able to charge the unit via a suitable usb charger.does a dongle work very well with ipad? not techno sort of people at all
