Which Sikaflex product to use? (1 Viewer)
Euro330
Banned
Aug 16, 2019
390
485
Carnoustie
Bailey Advance 640
About 5years
I am just about to start an upgrade/change on the Moho (Bailey Approach Advance 640) Changeing external lockers/EHU/Filler point and vents from original White to Black.
Most will be replacements and a couple plastic painting but all will obviously be resealed.
Used Sikaflex EBT + before for some jobs but cant decide on this, the 512 or 221.
Cant really get a definitive answer from their website, Youtube vids of conversions or general trade.
Anyone used any of above before? and do you think it was best product or wish they had used something else?
The straight replacement EHU (but in Black) comes with a foam gasket, bin this gasket for sealant or use it in conjunction with sealant?
All views and oppinions appreciated.
34127
A lot of folks prefer Puraflex PU40 to Sikaflex. I have used it to seal most things on my van and not had any issues with it.
Vic. Parsons.
415
1,970
Wales
Hymermobil S740
since 2014
Personally, I wouldn't Sikaflex them on. If you ever have a problem with them in the future, you'll struggle to remove them.
I can't remember the name of it offhand but I've used some stuff that is like bluetac but black to seal our roof lights. It's a very good flexible seal but the part is relatively easy to remove if you have to.
Euro330
Euro330
Banned
Aug 16, 2019
390
485
Carnoustie
Bailey Advance 640
About 5years
Does the Puraflex remain flexible, weather resistent and act as an adhesive aswell? Cheers.
Gellyneck
9,249
18,346
More than toes wet now!
And at £5 odds a lot cheaper than Sikaflex assuming you need the joint strength it gives.
Euro330 it comes in both black and white so guess you could get what suits. You'll get it from Toolstation who have a branch just of Kingsway in Dundee.
Gellyneck
9,249
18,346
Outline spec here
Euro330
Euro330
Banned
Aug 16, 2019
390
485
Carnoustie
Bailey Advance 640
About 5years
Yes know toolstation, have Screwfix and sons 20% B&Q discount card aswell. Not overly concerned over the cost as it is going to prove a fairly costly excercise anyway, best product is what I am concentrating on just now. Shall investigate though. Cheers
Gellyneck
9,249
18,346
If you search Puraflex on here you'll find an number of threads that give very good reviews of Puraflex after use on solar panels, sat dishes, etc.(y)
Garratt
192
358
Miskin
Rapido Dreamer D55+
Since 2017
W4 caravan mastic sealing strip sounds like the stuff you are describing.
For what it’s worth, I’d use Sikaflex EBT from Screwfix.
Euro330
Euro330
Banned
Aug 16, 2019
390
485
Carnoustie
Bailey Advance 640
About 5years
Yeah think thats next step. In mean time gonna try a few sample tests using Sika or Puraflex on old Fridge freezer lids and sides to see what is performing best.
Euro330
Euro330
Banned
Aug 16, 2019
390
485
Carnoustie
Bailey Advance 640
About 5years
Thanks for everyones comments and views, however here is an update with reply from SIKA on which product I should use.
Never heard anyone mention it but sure I have seen it before.
To: "James Taylor" <taylor.james@uk.sika.com>
Date: 18/02/2020 09:59
Subject: Re: Re-Sealing Motorhome External- locker/storage plastic doors + External Fridge/Freezer Vent Frames
Anne Hobbs
James Taylor <taylor.james@uk.sika.com>
Tue 18/02/2020 09:26
  • You
Good morning Anne,
Thanks for you contacting us.
We would suggest Sikaflex-521uv for this as is available in black and widely used for this type of application.
I hope this helps and should you need any further information please do not hesitate to contact me.
Kind regards
James
James Taylor
Technical Services Co-ordinator
Target Markets - Industry & Sealing and Bonding
Captain Pants
451
2,640
Weinsberg PVC
Since 1982
If you were in the marine industry and keeping water out long-term out was your primary objective, it would be Sikaflex every time. Also, check out Arbo who produce a wide range of sealants for specialist applications.
53,514
150,388
I'm not a fan of Puraflex I don't like the way it drys with a pink hue.
For any item that may need removing you really don't want to use a PU adhesive better to use a non-setting butyl type sealant.
Euro330
Euro330
Banned
Aug 16, 2019
390
485
Carnoustie
Bailey Advance 640
About 5years
Hi Pants are you thinking
Arbomast Auto grade
was just looking it up there, or any other suggestions? Graeme
Captain Pants
451
2,640
Weinsberg PVC
Since 1982
Arbomast Auto grade
I’ve used that for fixing glazing into aluminium including vehicle windscreen on a classic car and for that it was very effective, but on balance I think the advice given by SIKA above is appropriate. There’s a trade off between good long-term adhesion and non-setting stuff, but even the latter goes hard and brittle over time.
17,637
43,382
when built, bailey would of used carafax non setting mastic
Euro330
Euro330
Banned
Aug 16, 2019
390
485
Carnoustie
Bailey Advance 640
About 5years
Thats kinda what I am looking for Big 1. Having said that when used Sikaflex EBT + before it sets firmly but still very rubbery and easy to remove if neccessary. Might just stick with that as I know how it performs and know how to work with it.
Paddywack
1,211
2,281
Neasham, Co Durham
Hymer ExsisT588
Unless you are going to run the test over a ten plus year period, across a wide range of temperatures and at different levels of humidity, your tests will provide little useful information.
Captain Pants
451
2,640
Weinsberg PVC
Since 1982
Don’t forget constant vibration and the occasional shock!
Paddywack
1,211
2,281
Neasham, Co Durham
Hymer ExsisT588
Follow Sikaflex's recommendations.
If you are planning on keeping the van a few years then anything else is a false economy.
Garry - June
413
818
Pershore, Worcestershire, UK
A Class Frankia
Take a look at Tec7 sealant....we lived aboard a boat for some years and was put on to this stuff by another sailor when replacing various seals above and below water...it remains flexible and in my opinion is far superior to Sikaflex...I use it on the MH now too...
Apr 26, 2016
281
349
South West Wales.
Le-Voyageur LVX 9
since 2000
CT-1
is an all rounder
is a sealer adhesive found in most builders merchants,
it is comparable with sikaflex, and is available in white and black
have used it instead of sikaflex and found it does everything it says on the cartridge
and slightly cheaper than sikaflex
it holds down solar roof panels with no screws, and can be cleaned off if needed
(G H Awnings use it to seal and attaching alloy strips,
for water sealing roof to awning gaps.
"Nuff Said"
Jan 18, 2016
682
723
North Wales
Adria Coral 670SLS
A long time
Stixall Extreme for me. High bond PU adhesive and gives excellent results.
Doesnt dry and crack like Sikaflex.
I believe it is used at Vanbitz.
I have used it on fitting a new electric box on the side of the van. Attaching foam pads to polyethylene boxes and re-sealing around the base of the garage where the Sicaflex peeled off!
Good luck with all this advice.
Paddywack
1,211
2,281
Neasham, Co Durham
Hymer ExsisT588
Which Sikaflex product are you comparing it with? They have 56 adhesives and 71 sealants alone.
I worked in marinas and around boats all my working life, I have trusted mine and others safety to the strength of the bond provided by the APPROPRIATE Sikaflex product in many critical situations. TEC7 is a generic sealant / adhesive, it is in no way comparable in quality to Sikaflex.
The key issue with Sikaflex and other similar chemical fixings is that amateurs do not follow the proper instructions with regards to cleaners and primers - there are again a whole range of individual products to match up with specific sealant or adhesives and a lot of people think a swipe down with acetone will suffice - it won't.
Paddywack
1,211
2,281
Neasham, Co Durham
Hymer ExsisT588
Wish they would tell the coach builders that!
They do, the ones that don't spoil the ship for a happeth of tar. Watch the "Building a Morello" video - I don't know if its done on purpose as product placement but I counted a box of Sikaflex five times in the thirty minute video.
