OldAgeTravellers
Hi All,
I am sure this has been asked before but I can't find it. This is also a bit long but I want to get all the info down so as to get some accurate replies.
Firstly, we have a Hymer on a fiat chassis uprated with front springs and Alko Chassis to 4.5 tonne
Registered July 2012, I thought it was a 150 engine, but the registration only says 2008 Euro 5
Engine size is 2287 cc Power 109 kw it is French registered but built in Germany the original UK V5 gives no more info..
Now the handbook says use only Selenia WR P.E. SAE 5W-30 to Fiat 9.55535-S1 specification well it wouldn't it! To buy that I would have to drive a 100km round trip and pay ten times the normal price. I also note that Ford with the same engine say only use their own oil and Peugeot say the same. So their Dire warnings can be discounted I believe.
Fiat do say in an emergency an oil with at least ACEA C2 performance is acceptable.
Now I have always used Shell Helix Ultra 5W-40 fully synth which is easy to get reasonable price and the specifications say it is ACEA A3/B3 A3/before now is that better than ACEA C2 or different.
It also says that it meets Fiat 9.55535.Z2 specifications now is that better or worse than Fiat 9.55535-S1 specification. All so very confusing.
Also bearing in mind that this vehicle spends most of it's life in the south of France, Spain, Portugal & Morocco. So is the 5W-40 better to use as it is often at temperatures around 40deg.
OK next Summer we will be going to Scandinavia but the -5deg Winter temp is the same on both oils.
Now the Shell online Lubricant checker says:
Ducato Box 150 Multijet 2.3 (109kW) (Ducato) (DT) (2011-) which looks to be the one we have to use:
Helix Ultra Professional AT-L 5W-30 in the UK and in Spain
Now I have never seen this oil in the Supermarkets or in the Equivalent of Halfords over here. We are driving to the UK in a couple of days and the oil is at the bottom level mark so i need to put half a litre or so in to be safe.
so can I put this in which I have.
Or must I search around for this:
Broken Link Removed
Thanks for any educated help rather than stupid comments which seem to be getting more and more the norm nowadays.
Steve
Broken Link Removed
Steve
