Check out Teltonika like Orion said, we’ve fitted a RUT950 and it works brilliantly with the Panorama Great White aerial.I want to buy a mifi unit for my new motorhome I think there’s Maxview and net gear is there anything else if anyone got one how do they perform
Should have gone to SpecsaversBlimey, I had to have a double take on the thread title, I thought it read Which Is The Best MILF and Googled it I’m scared for life now
Wonder how many likes that would have got
is the phrase MILF a brand name - i would hate to get it confused with something else ....Using the term Mifi is becoming the same as saying Hoover when referring to vacuum cleaners.
Mifi is a brand name for wireless routers that, I think belongs to Novotel or some other company.
We have 160GB of data on each of our two phones (EE) so we added a 4GB data only sim (EE) at £6.40 a month for the router (Teltonika). We just move data to the router sim as required.I'm also considering adding MIFI but I'm not great with this stuff!
Current situation is that we have two phones one with unlimited data so we normally use the hot spot to firestick to watch Netflix etc when we can get a decent signal.
If we install MIFI do I need to subscribe to get yet another SIM for the unit?
Also can you get a decent unit without a roof antenna?
Thanks for the infoWe have 160GB of data on each of our two phones (EE) so we added a 4GB data only sim (EE) at £6.40 a month for the router (Teltonika). We just move data to the router sim as required.
Personally think if your not going to add a decent roof antenna with a router, stick to using your hot spot because you won’t see a great deal of improvement.
We’ve seen a brilliant improvement by having a decent aerial (Panorama Great White) and router from when we hot spotted.
My Teltonika RUTX11 came with attachable aerials just like many home wifi boxes, and it all worked fine. The point of the roof antenna is that the signal strength inside a vehicle, especially a panel van, is very much reduced. Near a window, or a fibreglass section of the body/roof would be OK for signal strength.Also can you get a decent unit without a roof antenna?
Hi Hettie's Crew, can I ask where you bought the great white antenna from? Also, did you fit it yourself?We have 160GB of data on each of our two phones (EE) so we added a 4GB data only sim (EE) at £6.40 a month for the router (Teltonika). We just move data to the router sim as required.
I bought it from CO-STAR who are based in Harrogate. I rang them to ensure I was getting the right one, 2x2 mobile 2x2 WiFi and the right deal. It comes with about 30cm of cables from it so extensions are usually required. They supply it with 5 meters of aerial extension cables which was way too much for us to hide, so I had them shortened to 1.5 meters.Hi Hettie's Crew, can I ask where you bought the great white antenna from? Also, did you fit it yourself?
Cheers,
Kev
That what I do. One phone with unlimited data, SIM each for the Mrs, teenager and the mifi and transfer data around as neededWe have 160GB of data on each of our two phones (EE) so we added a 4GB data only sim (EE) at £6.40 a month for the router (Teltonika). We just move data to the router sim as required.
I have recently purchased an E5577. can you say what antenna you have pleaseThe Huawei E5577 is cheap, reliable but 4g only. So if you can get and want 5g it's no good.
We are looking to change unit from the Huawei as had for ages even bought a new battery for it. We did buy an Huawei E5786s, few years ago as a spare but although newer, the older E5577 always got a stronger mobile signal.
Do like the flexibility of a battery powered unit which rules Teltonika out. Netgear looks good but expensive and since experiencing the Netgear Aircards am suspicious of Netgear quality and performance.
Having typed this out ... have decided to stick with the E5577 for the time being, have a decent antenna which we use rarely but does help.
I have a poynting xpol it is omni directional. Have not fixed permanently just stick it on the roof when needed. Tried a couple of cheap square ones, one made no difference the other made a minor improvement.I have recently purchased an E5577. can you say what antenna you have please
Thank youI have a poynting xpol it is omni directional. Have not fixed permanently just stick it on the roof when needed. Tried a couple of cheap square ones, one made no difference the other made a minor improvement.
Bear in mind we rarely need an external antenna, athough recently at Ferry Meadows it made a big difference so much so that I have decided to keep the antenna in the van after all
I tapped into some 12v wires powering the TV aerial booster and fitted a small rocker switch.Ive been looking at these. How are you powering it?
I have a different router, a Huawei B535 and i power this with one of these, the price seems to have gone up a lot since I bought mine last year.Ive been looking at these. How are you powering it?
