Where's the emergency alarm disable button? (1 Viewer)
pwilmo
284
420
Kings Lynn, Norfolk
Auto Roller 747
My motorhome is a Bessacarr 745E and since all our alarming problems my wife is dreading being left alone with the alarm singing out and no way to turn the whole thing off.
The alarm system is factory fitted Cobra.
Does anyone know where the Emergency Disarm Alarm button is hidden, or perhaps Bessacarr doesn't fit them?
I have searched all over. One of you Funsters out there must Know!
Jan 31, 2013
135
172
Scotland
CI Cipro 85
im a newbie
Hi, we have a cobra alarm fitted to our Cipro 85. The alarm works when you use the fob to lock or unlock the cab doors. This is the cab door locking fob. We do not have a separate fob for the alarm system. We have a small button with a flashing light on the steering column when you use the fob.
This light flashes when you lock the doors. When unlocking the doors using the fob you have 5 secs to place you finger over the flashing button. Also when you pull-up and switch the ignition off you have 5 secs to press the flashing light. We had the same problem as you are having. As a result we lock the cab doors from the central consul and use the motorhome door to exit the vehicle.
When we are on site we do not use the alarm, only when we leave the m/h in a busy area we use it! Who takes any notice of any alarm unless you are on the inside.
Jan 31, 2013
135
172
Scotland
CI Cipro 85
im a newbie
In addition to my post yesterday, the button controlling the alarm is near the gearstick and is 8mm in diameter. You must cover this with you finger as I described to stop the alarm system. What I failed to mensioned, under the bonnet there is a reed switch. When the alarm is alive a shaking of the m/h or movement in the m/h it will go off. Not funny in the middle of the night. Only you can decide when you want to activate the system!!
