Where's the access to the fresh water tank? (1 Viewer)
Mar 24, 2013
35
62
Devon
Since 2009
I have a 2011 Fiat Autotrail Tracker SE. I can't find the access to the fresh water tank in order to check the float and the general condition inside the tank. The manual gives no clues!!! Can anyone help me please???
Also, is it possible to access the waste water tank for inspection???
joka250
907
1,551
Fylde Coast.
Since 1985
I think you will find an inspection access in the bottom of the tank, about 5 inch diameter, unscrew. Have get underneath to access. Don't think it's a float on that model. Screw in sensors on side often, again underneath to access.
tonka
10,669
21,007
Cannock, Staffs
A class Burstner 800
Since 2000
No top access and no float. They use sensor rods. Big screw cap on the bottom but won't give you access to much only a wet arm. :D
D
Mar 24, 2013
35
62
Devon
Since 2009
Thanks for the replies! Doesn't sound hopeful then! If the sensor rods need replacing does that mean fitting a whole new tank??!!!
joka250
907
1,551
Fylde Coast.
Since 1985
Not sure but they do unscrew, have spoken to people who have taken them out and cleaned them but mixed results. New ones available from www.sargeant.com but I think £50 or so each.
No tank does not need replacing.
tonka
10,669
21,007
Cannock, Staffs
Since 2000
It's a common complaint of inaccurate water readings on Autotrails. Most, like me, just put up with it.. Well I did until this week when I got rid. :D
Oct 14, 2007
3,895
5,835
Rochester
Auto-Trail Mohawk
16 fun filled years
The waste tank sensor rods on my 2013 Auto-trial Mohawk are or was just stainless steel screws, I would think the fresh tank will be the same. I replaced them with Horst miracle probes because it drove me round the bend with the readings not being correct all the time. I dropped the tank out to do the work, it was only 4 bolts and the harness to disconnect so easy enough.
May 7, 2016
6,619
10,343
West Sussex
Carthago Compactline
Since 2003
I was trying to help a single camper with a grey water drainage problem. She had recently bought a 2 year old motorhome of British construction. I was surprised to discover a modern motorhome without easy access into the tanks for inspection etc. I thought this would be a standard facility in a recent build. Am I being naive or have I just been spoilt by Hymer?
Oct 30, 2010
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
Would suggest not doing this with a full tank though. :LOL::LOL::LOL:
Richard.
Oct 8, 2014
1,522
2,725
Wiltshire
Autotrail Excel 600B
Previous VW Camper + Caravan
When the fresh water display on my Autotrail started displaying incorrect readings, I cleaned the sensors by draining the tank, removing the large inspection cover and then spraying the sensor area with a kitchen spray bottle, filled with white wine vinegar. After leaving it a while, I gently rubbed over the sensors with an abrasive pad. Rinsed it all thoroughly, replaced cover, and all was working again.
Minxy
31,927
63,447
E Yorks
Would filling the tank and putting in some descaler, leaving it in for a while and then emptying it work? Obviously need to be careful not to use anything corrosive to the water tank etc.
D
Mar 24, 2013
35
62
Devon
Since 2009
Thanks again for your helpful responses! I just find it so difficult to get easy access to any vital parts on an Autotrail - except the cupboards when the door hinges loosen or the fascia trim falls off!! But I do like the spacious bench layout (two singles or a double). If I could find a German or French MH with a similar layout (without drop down over-cab bed) I'd go for one. Far better build quality.
D
Mar 24, 2013
35
62
Devon
Since 2009
Revolver - is there an inspection cover underneath the Autotrail, then ??
Minxy
31,927
63,447
E Yorks
Unless he's got super stretchy and skinny arms like Mrs Parr from "The Incredibles" I should think so. ;)
May 24, 2014
648
2,563
North Devon
Autosleeper Kingham
Since 2013
This is an issue with so many motorhomes and vans. I gave up on the accuracy of the existing system and instead l top up the fresh water each and every day that l can and dispose of the grey water as and when the opportunity arrives in the correct place l may add.
Silver-Fox
9,033
26,683
Cheltenham Spa
Rapido
im a not so newbie
Smugness is not a good quality :D
