I don't even know how to fix a bike to a bike rack, so I have no idea if it is even feasable, let alone how to secure the wheelchair.
Can it be done?
Can it be done?
I used to put my wife’s wheelchair on the bike rack, when folded the rear wheels fitted into the grooves, used the straps on the wheels and the clamping arms fitted at the top ends, never had a problem, wheelchair would probably be lighter than two bikes.I don't even know how to fix a bike to a bike rack, so I have no idea if it is even feasable, let alone how to secure the wheelchair.
Can it be done?
Thanks, I'll give it a go, tho, I'm not at all sure how the clamping arm is supposed to work.I used to put my wife’s wheelchair on the bike rack, when folded the rear wheels fitted into the grooves, used the straps on the wheels and the clamping arms fitted at the top ends, never had a problem, wheelchair would probably be lighter than two bikes.
If your not sure how to clamp it then use short lengths of rope and tie it on, I often doubled up like that, but then I do tend to go over the top, it’s the same when I tie a load in my trailer, more rope than they use to tie up a ship.Thanks, I'll give it a go, tho, I'm not at all sure how the clamping arm is supposed to work.
Weight is not an issue, the rack says 60kg, and as I can lift the chair unaided, it's obviously a lot less than that.![]()
