Just been there and done than .... 180Nm or 130 ft lb
LOL ! Believe me.. at 130 ft lbs 3ft lbs aint gonna make too much differenceSame here, 133 ft lb though.
Yep..... Could easily be the discrepancy between torque wrenches. They don't stay calibrated forever.LOL ! Believe me.. at 130 ft lbs 3ft lbs aint gonna make too much difference![]()
I don’t disagree with you as that’s exactly what I was alway taught and I still do it today..And too many leave them fully "set". You should ALWAYS back the setting to Zero after use. In industry it is shown to have a marked effect on accuracy.
On the Sprinter, Alloy wheels 180Nm. Steel wheels 240Nm (From the Owner manual)
How do you explain pre-set torque wrenches however?
I was a vehicle technician in the RAF so I never came across them either but my son is an aircraft engineer (RAF) and they use them, so does my customer at work who has vehicle re-manufacturing lines in the Netherlands where these pre-set wrenches are also used.Surprisingly I have never come across one. As my need is for a variety of uses from old Classics to new R-V`s I only have ever had Adjustable one`s.? The wheel nuts on my last R-V where in the range 350LB/ft. and I had to use a "multiplier" to get them off, and when they went back on I pulled them up by hand and then went to a local Truck Garage and borrowed theirs!.
I was told they need re-torquing after a 50 mile drive on Merc sprinters, after the initial torque setting to check them, is this true?
We used preset torque wrenches on the production line at Lotus. They were checked for calibration every week by a qualified person, or if one was dropped. The calibration equipment was checked regularly as well. Every torque wrench was logged as part of the process so they couldn't be switched around.How do you explain pre-set torque wrenches however?
I once read a document from Norbar, who had carried out some research on this. They stated that a torque wrench should preferably be returned to less than 25% of its maximum range, but should never be returned to zero. In tests that they had carried out, they also found that leaving torque wrenches set at higher figures did not cause their accuracy to drift any further than returning them to lower settings, but it did cause the total drift to occur more quickly although over time, all of the equipment stabilised at similar figures.
