What's this relay box for?
Derbyshire
Elddis Accordo 105
since 2014
I'd have said d+ relays for fridge and battery charging (which is what I'm looking for) but they're all 5a fused and the relays are tiny half inch square things.
2014 Elddis accordo 105
It's in the bodywork pillar behind the drivers seat, the main red+black incoming thick 12v cable is just on a connector to a thick green+white and dissappears under the floor.. No big relays to be seen.
looks like the D+ relay to me, most vans they one fit as the D+ terminal of the alternator can't handle the load of all the items that need to be switched in a Motorhome.
It's not central locking then could be the step?
This is inside it the relays look like 5a rated although I can't read the writing
No electric step... There is an auto watch alarm though 🤔
This is in resources section 3 shows the connections in the pillar behind the seat, I know you have a Pug but would imagine them to be the same it might help to figure it out.
I've got one in my van, located in close proximity to the main 12v distribution box.
It's a CBE SRX250 RELAY FUSE BOX. Mine powers/operates the orange marker lights.
On the Elddis vans, it does the switching off of the hab electrics and switching on of the fridge to 12v when it senses the alternator output via the D+.
It's wired across to the BCA PDU and fires relays on the BCA PDU PCB.
Ours failed 3 years ago and had to be replaced.
I carry a spare on the van now as they are a pain to get hold of.
Thanks 😊, how can it handle the 10a fridge supply? Also what's BCA and PDU?
I would imagine you recognise one of these, it's a PDU (power distribution unit) made by BCA and it's a relay in the PDU triggered by the CBE SRX250 relay fuse box that switches the fridge 12v supply when it sees a D+ signal.
Changed one of these recently on our Bailey AA625 2014. Red and amber marker lights had stopped working. Unit is a CBE SRX 250 RELAY FUSE BOX. It controls the marker lights, fridge light and hab central locking and/or electric step if fitted. Got mine from Halesowen Caravan Centre £52 quid including vat and p & p. Prima price was circa £90 quid. All good again now.
If ours goes I'll repair it at that price 🤣 £2 relay and soldering iron.
The mission is to beef up the B+ wiring so when the fridge is on the charging voltage to the leisure battery doesn't drop to 13v.
Nothing's ever simple is it, I mean how complex can a new piece of wire be 😏
Made a diagram of what I've got, there's connectors, fuses, what look like bodged taped up joints and finally onto a white multi plug on the pcb.
Options.. Put everything back together and forget about it 🤣
Or run an additional 25a fused 10mm cable in straight from the +battery to pcb. (probably have to solder it on somewhere as the relays are pcb type)
What does the collective think? 🤔
It’s the psa bodybuidetsconverstion kit it allow the connection to the main loom
I have a schematic of the BCA PCB if you want it Richard.
Finished fitting an additional 6mm fused cable today. The clamp meter shows the electrons prefer it with 10 amps worth using the new cable and only 3.3 amps on the old original cable. The charge voltage goes up thus...
13.4v before (although it has in the past struggled to get past 13v for some reason) and 13.8v with the new additional cable.
It's about a 2.8m run for the new cable and I soldered it on to the original cable close to the pcb plug and insulated it..
I also fitted a new 6mm ground cable from the starter battery post to the pcb via 2 header pins I soldered in on the ground track.
Used a midi fuse holder and 30 amp fuse 👍
So all in all I'm reasonably pleased with it. Bit of a bodge pcb end but what can you do? As long as it works ☺️
A 0.8v gain then 🤩
Journey home the other week 👇
Hi, I have an Elddis Sunseeker 2012 and it's switching off the had electric but it's not switching on the fridge to 12v .
Would it work if I changed it?
Thanks in advance
Thanks in advance
If your refering to the CBE SRX250 relay fuse box, then that is sending a D+ signal (engine running signal) to the, in our case, BCA power supply unit, and the D+ signal powers a relay to turn off the habitation area power, and a relay to switch over the fridge to 12v from the starter battery, so if your hab area power is being switched off, then it's unlikely to be a faulty CBE SRX250 relay fuse box.
Our BCA power supply unit does have a fuse allocated to the fridge on the front panel.
Thanks for the swift response, I checked the fuse located in the pdu and it's working properly or are you referring to another one? Also I realised when I chose vehicle instead of aux battery nothing is working. It looks like there's some fuse broken but I can't find it
You will have a 25amp inline fuse on the cable from your hab battery to your BCA power supply unit that sounds like that may have blown if you have no 12v on "aux"
Ours is hidden under the small gap between the underside of the hab battery box and the floor.
Isn’t D+ just a signal wire to say the engine is running to things like the fridge as mine is only 2 amp fuse going to the fridge.
