the M25 is not part of the ULEZ zoneIt's been a couple of years since we drove south to the Dover ferry port. We've always used the Dartford crossing but I understand you have to pay ULEZ as well as the toll now. Is this correct?
Better idea is to put false number plates on.I suggest you register for autopay on the TFL website so that even if you do stray into ULEZ ( you won’t if you stay on the M25) then it’s only £12.50 instead of the £180 (?) fine
The Dartford crossing is tolled.It's been a couple of years since we drove south to the Dover ferry port. We've always used the Dartford crossing but I understand you have to pay ULEZ as well as the toll now. Is this correct?
I think my Garmin regards the Dart charge as a toll so I suspect would route either via Heathrow (M25 anticlockwise) or going into ULEZ to cross the Thames.Make sure Sat Nav is not set to avoid tolls![]()
Would‘t need A12The Dartford crossing is tolled.
Inside the M25 you are into the ULEZ areas, but there is no reason to go there.
I'd strongly suggest you set up a Dartford Crossing account here
It costs nothing to set up
Even if you only use it once in a blue moon, it worth doing.
It's simple to do at home with your wifi.
It is a lot harder to do on a mobile phone whilst travelling.
You can put as many vehicles as you like on a single account, so add the other car, the kids cars etc.
You will be sent an automated email each time your account is used, so you will know who owes you £2.50, which is a lot less than the fine if you 'forget' to pay!
As long as you log into your account at least once per year the account will stay open.
In answer to the original question:
How to get from ooop t'north to Dover:
M40, M1, A1(M), M11, A12 to the roads to Dover M2, M20. In all cases it's faster to go around the M25 clockwise (Via the Dartford Crossing).
For the M3, A3, A25, and M23 then anti-clockwise to the M2 and M20 is fastest.
For the M4, it depends on the traffic at the given moment, anti-clockwise is slightly fewer miles, but may not be fewer minutes.
Also for Folkestone, as long as they don't have thousands of trucks in the 'Brexit Benefit' queue then the M20 is the fastest.
For Dover, especially in the holiday season, the the M2 is the fastest, especially as you can get off at any exit and go via A256 in case of heavy traffic or roadworks.
(Just be aware if they are using Manston as a Lorry park, the A256 is the route the lorries will use)
It all depends where in the North. Since the OP is in Newcastle (presumably upon Tyne rather than under Lyme) the M40 is well out of their likely route. From West Cumbria our normal route is to cut across to Scotch Corner on the A66, joining the main route from Newcastle there, then A1M, A1, A14, M11 to M25 (although with the holdups at Darrington on the A1 we’ve been trying alternatives!). We don’t touch the M1 or A12.In answer to the original question:
Just be careful you don't get tempted to turn off M25 to visit somewhere and get clobbered for ulez
Your safe on the m25 as far as ulez is concerned
Nearly Di and the cost would have been £600Dont turn off M25 for fuel or something else you can easily stumble into ulez.
£12 ! its £300 a day for usI suggest you register for autopay on the TFL website so that even if you do stray into ULEZ ( you won’t if you stay on the M25) then it’s only £12.50 instead of the £180 (?) fine
Depends where you are going to in the "North"Nah, just stay on the M25 and A282 (Dartford crossing), then M25 and M20 and you will be fine
we always travel from just north of Newcastle upon TyneIt's been a couple of years since we drove south to the Dover ferry port. We've always used the Dartford crossing but I understand you have to pay ULEZ as well as the toll now. Is this correct?
No.BUSBY.It's been a couple of years since we drove south to the Dover ferry port. We've always used the Dartford crossing but I understand you have to pay ULEZ as well as the toll now. Is this correct?
I was just pointing out that as a rule of thumb:It all depends where in the North. Since the OP is in Newcastle (presumably upon Tyne rather than under Lyme) the M40 is well out of their likely route. From West Cumbria our normal route is to cut across to Scotch Corner on the A66, joining the main route from Newcastle there, then A1M, A1, A14, M11 to M25 (although with the holdups at Darrington on the A1 we’ve been trying alternatives!). We don’t touch the M1 or A12.
I know, I'd sooner do Portsmouth to Spain but it's £75 dover/Calais and £575 Portsmouth/Spain. Even with the extra fuel and tolls I can't justify it.Avoid the lot go by Harwich, hull, Portsmouth, Poole or Plymouth.
But Newcastle or Hull to Rotterdam, by the time you take camp fees, fuel, tolls and ferry costs into consideration may be both faster and cheaper.I know, I'd sooner do Portsmouth to Spain but it's £75 dover/Calais and £575 Portsmouth/Spain. Even with the extra fuel and tolls I can't justify it.
Go down to the Ferrybridge services on the A1 and turn left (east) towards Hull, 2nd junction take the M18 until you get back onto the A1 which is after Doncaster, it’s 7miles longer and an hour quickerIt all depends where in the North. Since the OP is in Newcastle (presumably upon Tyne rather than under Lyme) the M40 is well out of their likely route. From West Cumbria our normal route is to cut across to Scotch Corner on the A66, joining the main route from Newcastle there, then A1M, A1, A14, M11 to M25 (although with the holdups at Darrington on the A1 we’ve been trying alternatives!). We don’t touch the M1 or A12.
Worth remembering that 'short' cut next time we are up that way!Go down to the Ferrybridge services on the A1 and turn left (east) towards Hull, 2nd junction take the M18 until you get back onto the A1 which is after Doncaster, it’s 7miles longer and an hour quicker![]()
There was an article on here a few years ago about a motorhomer who had set his SatNav to avoid tolls which he thought would do him well in France but which had then routed him into the Blackwall Tunnel and the Ulez allowing him to accumulate further penalties while he was abroad for 3/4 months.I think my Garmin regards the Dart charge as a toll so I suspect would route either via Heathrow (M25 anticlockwise) or going into ULEZ to cross the Thames.
Yep it is. Done this a number of times in the last 6 months and generally it holds you up for no more than 20 minutes overall. Darrington road works are frustrating as hell but it usually does keep moving.Worth remembering that 'short' cut next time we are up that way!
It looks like it's traffic dependent though
Just buy a van that's ULEZ compliant
