What water connector is this?
Burry Port South Wales
Since 2003
And how do you release it?
The blue one is a Reich, its the dark coloured one with the brass insert and the blue ring which I'm interested in.
Ed
no idea on the manufacturer but looks like a posh version of a standard push fit equal tee fitting
Press the light blue collar into the body and yank the pipe, they can be really tight. They are used for compressed air fittings as well.
Ps Yank is a technical term. :)
Use something to push the pale blue bit in, can be difficult, a suitable spanner is good.
Thanks guys, I will have a go the T piece has developed a leak.
Ed
There is an O-ring inside, a smear of silicon grease may help if you haven't a spare. But you'll get one opposite the Casino.
Be careful with the size if you replace it, it will probably be 12mm, caravan pipe size. Back ir the good old days they were colour coded.
Removed all cleaned and refitted, T joint still leaked, drained the boiler again removed and cleaned applied silicon grease to offending joint refitted no leak. Result SWMBO can now use the loo flush again.
Cheers for your help folk, can now go and join the Funsters having a wine or three with the winnings from the quiz.
Ed
Edit I'll buy a new fitting tomorrow.
