Hello, I would like to fit a solar panel on my van. Its a flexible 150w panel and I have made a good sturdy frame for it out of aluminium angle bar. I am going to use 3M VHB tape to stick special plastic corner brackets onto the van roof which I think is fiberglass sheet over plywood. I am happy enough with this choice of adhesive as I have looked into it. I was put of with sikaflex and any other super solid PU glue because it sounds way too permanent and messy.
However I could do with some advice on a few things. Firstly what is a good sealant the use? I intend to go around the edges of the plastic feet/brackets to seal them just to keep the tape dry and for tidyness.
The other thing I want to do is use the hole in the roof where the Status antennae was. I want to run the solar panel's cables down through the hole. I intend to keep the fixtures of the antennae. The bits on the outside of the roof of the van where the pole goes through and its seals as is. They are fine.
Then I want to stick SOMEHOW a square click lock lid plastic food storage container over the antenna's hole onto the roof. The storage box is the kind of thing you get in most shops with blue latches on it. It could be made of food grade Nylon. I don't know for sure what its made of. This should keep the rain out and also if any water did seep in there the seals on the antenna's fittings would keep out anymore water. The box need to be firmly stuck on but not super bonded. I also want to run mastic/sealant/ around the joint.
Then I intend to stick a special plastic cable junction box onto the bottom of the food storage box. This junction box is meant for solar panel fitting and has gromets and O rings with it to run the cables into. I want this to be well bonded onto the plastic box. I might use the VHB tape here again. I then want to run sealant round that joint too.
The junction box has a nice groove on its underside to hold sealant/adhesive and a nice flange. It should stick pretty well to the box.
The top of the storage box has a lip all around which I could remove to give me a flat face and flange which might be better and also a good keyed surface as i will file of the plastic lip. The flange should hold a bead of sealant in there quite nicely.
I think I need gap filling ability and UV stablisation.
So what sealant and what adhesive should I use?
