If you buy a pass through it is a much easier install and needs no additional switches or relays and no remembering....not familiar with sunshine solar I'll have a look at their range..atm I'd guess they rebadge others products but ?
As I mentioned previously, we have a Renogy 3000w which in conjunction with the Fogstar 300Ah lithium ..... They're now into their fourth year together ...I have this problem. I'm in the process of fitting a 300A/h fogstar and ultimately would like a 2000w Multiplus, but I just don't seem to have the space to fit one. Which inverters are good for integrating with the existing 240v system but without the size of a multiplus? I don't think a Victron inverter would actually fit either.
Victron do a compact version of the 2000va Multiplus which is a bit narrower.I have this problem. I'm in the process of fitting a 300A/h fogstar and ultimately would like a 2000w Multiplus, but I just don't seem to have the space to fit one. Which inverters are good for integrating with the existing 240v system but without the size of a multiplus? I don't think a Victron inverter would actually fit either.
As I said they often have sales so should get a decent one under 300.Just had a look at sunshine solar reviews 30% are 1 star however this means 70% are 5 star and the assumption that unhappy people are more likely to leave a review than happy people ??? They do appear to be very similar to the many mid priced Chinese ones marketed by importers under various names and are more expensive than many (including Renogy)
You can't run a coffee machine from a DC to DC.And would stepping up the 12v to ebikes voltage between significantly more efficientWhy not DC-DC charge the batteries and side-step the issue of noisy inverters... and gain some efficiency too?
Not sure you could DC to DC charge the e bike batteries as the 230v chargers manage the charging regime..Why not DC-DC charge the batteries and side-step the issue of noisy inverters... and gain some efficiency too?
Inverters aren't noisy, generators are though.Why not DC-DC charge the batteries and side-step the issue of noisy inverters... and gain some efficiency too?
The 2000w Renogy is, @ £399.99 (5% off currently for new customers).I've just had it confirmed that the Sunshine solar 2000W inverter charger isn't suitable for LiFePO4 batteries.
I've used a 2kw Renogy inverter for a year now, no issues.Hey guys
So im looking to get my Rimor set up for wild camping, Nothing major, But need to be able to charge my ebike and run a Nespresso machine, Ebike charger is small draw at only 4.0ah
Ive obviously been looking at Victron but then recently got told about the below which are significantly cheaper
Monthly event
Renogy offers high-performance solar panels, lithium batteries, inverters, and complete off-grid power systems. Ideal for home backup, RVs, camping, and sustainable living. Shop reliable solar energy solutions and achieve energy independence today! - Renogy EUeu.renogy.com
Anyone any thoughts?
Cheers in advance
Often cheaper from other suppliers...Google or ebayThe 2000w Renogy is, @ £399.99 (5% off currently for new customers).
Another decent name Edecoa (eBay)I'll have to do some further measuring but I think the Renogy might even be a little big for the space I have to fit it in.
before I went large with the victron 48/5000 for a full vehicle setup + methodical conversiton to gasless, in a previous setup, I charged my ebike battery with a cheapo Streetwise 150W jobbie, 30quid or so from toolstation or similar. The ebike charger is a trivial load and doesn't care about square wave inverter. If the only other requirement is coffee machine... think about other ways of making coffee? personally I use coffee bags when motorhoming, for the convenience.Hey guys
Edecoa 2,000 watt pure sine wave is what I've been running for a year and a half now with no issues, cost £180 iirc.Another decent name Edecoa (eBay)
Yes we dont have a mains charger just rely on solar and b2bI'm not too bothered about the charger side as I think my Orion XS and 600W of solar should keep that side of things happy, and we will only occasionally be on hook-up, so a 2000w inverter with UPS / pass-through is what I'm really after as long as it fits in the hole I have for it!
I had a Streetwise 300 watt inverter fail after 6 months.before I went large with the victron 48/5000 for a full vehicle setup + methodical conversiton to gasless, in a previous setup, I charged my ebike battery with a cheapo Streetwise 150W jobbie, 30quid or so from toolstation or similar. The ebike charger is a trivial load and doesn't care about square wave inverter. If the only other requirement is coffee machine... think about other ways of making coffee? personally I use coffee bags when motorhoming, for the convenience.
My mains charger was used for 2 nights last year, just to check that the 240v side of the van was working ok.Yes we dont have a mains charger just tell on solar and b2b
