How do you empty a black tank
Position over drain ,open slide valve & that's itHow do you empty a black tank
Two independently controlled feeds into one output pipe.I presume a separate drain to the grey waste
Did some research into this back in 2012, when I sold mine. Could not find anything European, with a Black Tank then. If you are only considering getting down under 7.5t, how about one of the lighter yanks?.
RS MotorhomesThinking of downsizing but would prefer to get a motorhome with a black tank, emptying a little tank every day or so must be a pita.
I have had two differing systems...
Want a garage pete, even on mine i can only fit 1 sunlounger in a locker, the other one goes under the bed.
Laika
Apparently very good build quality tooI can concur.
It was an option on some of the of the Kreos models, probably also on the Rexos as well.
Our bench style Thetford cassette ( c200?) is usually good for 4 days?
Fair bit bigger than the little cassettes I see on caravans and smaller vans.
Personally I think driving to find ground level disposal points would be more of a pain?
Problem with a black tank, unless you move a lot you can get a shit mountain below the toilet pan. Then you need a stirring stick to break it up. Then you need somewhere to store shitty stick
Plenty but mostly the larger ones: Concorde morelo, vario, phoenix, etc N&b standard on the 'proper' Clou's not so sure about Flairs. How smaller do you want to go?Thinking of downsizing but would prefer to get a motorhome with a black tank, emptying a little tank every day or so must be a pita.
