one Moho, two avtex tv’s only one picks up any tv channels, can’t see what the difference is using the a standard Omi-directional aerial not the strongest of signal where we are are, anyone any thoughts of what to check TIA?
Are they both using the same aerial but at different times.
Try the old-fashioned coat hanger method. It might surprise you.Yes same aerial, tried the main one initially didn’t pick up any channels when tuning in then I tried the other(only just fitted it for this trip) and it picked up all channels straight away, so I tried the other tv again still nothing
Do they both have the same power requirements?
Charlie
I think it's the same coax, simply swapping tvs over.Omni directional aerials are simply not up to modern digital tv.
You might find that the two aerial supplies feeding your TVs has one more powerful point than the other, either way you need to upgrade to a modern aerial.
We live line of sight to the nearest transmitter & omni directional aerial simply doesn't work, even though I could throw a stone at the transmitter.
I think your lucky that any of your sets pick up signals.
Thanks all for your responses, I’ve changed the coaxial cable with the one that worked and I now have channels so clearly an issue with the one supplied thanks again
I asked in post 5 if you were using the same aerial cable which under normal circumstances would presumably include the same coax.
