ThisIsTheLife
Hello All,
Would be very grateful for some advice and pointers.
I have a Chausson Welcome 35, based on aTransit twin RWD, 2010.
Considering fitting a solar panel battery maintainer, not huge output, and probably dashboard mounted when required/in storage.
I currently have a single output solar regulator/controller for the panel.
The vehicle has 2 batteries (main vehicle and ‘aux’) under the drivers seat, and 1 under the passenger seat (leisure), ie 3 batteries although there is some interlinking at various times.
My questions I suppose are:
Is there any way at all that I can use the solar maintainer with single output controller to maintain all 3 batteries while the vehicle is stored and at rest ,remotely, ?
If so anyone know where the controller outputs need to be wired to.?
Its hard to get my head around this conundrum as , as far as I understand and I maybe wrong, but there are numerous relays and switches which :-
With EHU the leisure battery gets charged (and maybe a small amount goes to main vehicle battery although not 100% on this)
With engine running the leisure and vehicle main are linked up and both get charged, not sure about the aux although would imagine it would.
At rest, ignition off, with nothing running or connected the aux battery is normally disconnected to save power for start only .
Then of course there’s the added complication of allegedly the panel over the Hab door needing to be on to charge the leisure battery when the EHU is connected.
Maybe it’s an impossible dream to have one simple solution to charge them all at once via the solar battery maintainer when it’s left stored at a remote storage facility, (and with the panel above hab door off) but would appreciate any inputs at all, no matter what.
Many thanks in advance.
And Kindest Regards
Andy
And Kindest Regards
Andy
