water tank supports (1 Viewer)
Feb 15, 2014
714
1,250
cambridgeshire
Bessacar E450
3 years
Had an autotrail in for mot this week and also wanted tank supports changed (it had dropped onto road on a recent trip and was held up with a ratchet strap).
The tank supports are hidden by the cover and had rusted through on the offside, was not too bad to change although bolts all very rusty,
probably a good idea to remove the cover and check the supports if you cant see they are ok if your motorhome is a few years old
Autotrail was an 08 plate on a ducato with alko chassis
Mar 15, 2019
518
941
AutoCruise Stardream
Newbie April 2019
Ours isn't an Autotrail but is an 07 Boxer on the alko chassis. Had the similar problem, hadn't given way but surprised how weedy the end supports were as had bent and come loose with the weight of the water. Beefed ours up, ground the rust off and hammerited it. Stronger than it came out of the factory now. Worth checking them as an easily neglected area.
Apr 12, 2012
1,698
6,386
N/E Lincs
Autosleeper Rienza
as above
Our Duetto tanks were held up by threaded rod hooked into the chassis with a piece of ply under the tank to spread the load. The rods weren’t even stainless.
After I was called out to a motorhome dragging it’s tank on the floor I made new brackets that were bolted to the chassis and metal plates under the tanks to spread the load.
chatteris
Feb 15, 2014
714
1,250
cambridgeshire
Bessacar E450
3 years
tank straps on the autotrail were just bent thin steel probably only half the thickness of the ones holding my bessacar tank
